Author Topic: Hydrogen: which isotope or covalent bond with other atoms do we need  (Read 6849 times)
Hi,
Which soup of atoms do we need to run an engine?
Hho?
H2 or H1?
D2?
NH3?
Please read the attached document. Add your Meyer knowledge and know that petrol contains hydrogen as the powerfactor...
Re: Hydrogen: which isotope or covalent bond with other atoms do we need
« Reply #1 on: July 30, 2013, 22:02:00 pm »
more
« Reply #2 on: August 30, 2017, 21:58:38 pm »
If atomic hydrogen is generated in a system at low pressure, the atoms will have a significant lifetime—e.g., 0.3 second at a pressure of 0.5 millimetre of mercury. Atomic hydrogen is very reactive. It combines with most elements to form hydrides (e.g., sodium hydride, NaH), and it reduces metallic oxides, a reaction that produces the metal in its elemental state. The surfaces of metals that do not combine with hydrogen to form stable hydrides (e.g., platinum) catalyze the recombination of hydrogen atoms to form hydrogen molecules and are thereby heated to incandescence by the energy that this reaction releases.
Molecular hydrogen can react with many elements and compounds, but at room temperature the reaction rates are usually so low as to be negligible. This apparent inertness is in part related to the very high dissociation energy of the molecule. At elevated temperatures, however, the reaction rates are high.
« Reply #3 on: August 30, 2017, 22:00:14 pm »
So air should be pumped thru yr cell to achieve a gas type that runs engines.
H reacts H2 doesnt.....
« Reply #4 on: August 30, 2017, 22:01:06 pm »
In electrolysis cells, H is in the waterbath. H2 is formed on the electrode.
« Reply #5 on: August 30, 2017, 22:14:12 pm »
Look what Gareth did with his carburator......
Plain electrolysis and air passing the electrodes...
http://www.keelynet.com/energy/garrett.htm
« Last Edit: August 31, 2017, 12:41:15 pm by Steve »
« Reply #6 on: August 31, 2017, 11:14:31 am »
it basically means that we MUST use a carburator system and not an injection system. We need vacuum or ambient air pressure like 0.5 mm merc. or 0 bar to give time for the hydrogen atom to react with with airs nitrogen. That results in way more atomic mass and more power and even a better burnrate.
« Reply #7 on: August 31, 2017, 11:17:25 am »
remember what Anderson said in his famous interview.
If you put the gas under pressure, it goes out..... No use for fancy injection systems.
His cell had a pressure controlswitch that switched the cell off at very low pressure already.
