Author Topic: How Stanly Powered His alternator  (Read 64450 times)
« Reply #8 on: March 30, 2008, 08:25:13 am »
(http://www.rediline.com/images/da3179.gif)
« Reply #9 on: March 30, 2008, 08:27:56 am »
no man, he was using house hold current to run his driver motor,,,, !!! YEAH,, so happy!!!!
Stevies Motor runs at about 220 volts 4 amps, 900 watts!!!!!!!!!! it is simple to hook this DC to AC Rotorary Generator to a 12 Volt car battery and power the driver motor, so now i understand how he was powering that motor!!!
dude, stan how did he know to do all this?? that man was either lucky he seen how this could be done from hanging around the military or either he is just one smart cookie!!!
OH MAN, dude,,, its another thing we now understand that he was doing,,, wow
Ohhhhhhhhhh the driver motor. Ya. cool!
« Reply #10 on: March 30, 2008, 08:34:41 am »
Southern Generators Inc
307 Cedar St
Greenville, AL
(334) 382-8453
These guys sell redi-line generators
snoopy2005
« Reply #11 on: March 30, 2008, 23:48:32 pm »
Fantastic findings Hydro!
So what do you think, he put in 900W of "household power" + the 15W controle power
and that was enough to run his car?
Frome those videos, do you see which WFC he used ? The new "he wont let us point a camera on..." or the good old cell?
J@H
« Reply #12 on: March 31, 2008, 01:14:53 am »
From the pics I think its that white PVC  type tank behind meyer.  From the article in the wireless world, Stan used 6 set of cylindrical cells to power his VW dune buggy for 4 years.
Great discovery hydro. I am glad I quit hanging out at the other OU forums. The alternator set up is the way to go. Now I am absolutely convinced. ;D
So my question really is this...was he pumping amps into his cell  through the alternator or was there really some sort of OU phenomenon that he discovered??
In otherwords we know for a fact that he used 900 watts to run the drive motor of the alternator. Thats given..the question is how much amps the alternator pumps into his 6 cylinder Tank cell or for that matter just one (original demo) cylindrical cell. Any ideas?
hydro
« Reply #13 on: March 31, 2008, 06:19:09 am »
well,,, based on stevies driver motor at 220 volts 4 amps, Thats the lowest amount of power consumed that i have seen to run a driver motor with the great torque it puts out...
Based on my 1995 Geo Metro alternator and 12 tubes i get almost 5 cc's per second or around 300 cc's a min.  it's understandable to me my alternators circumference is small where stanleys circumference on his alternator is bigger. A bigger circumference will give you longer field wire and also send much nastier shocks to the cell, where longer stator wire can not fit inside my small geo alternator. Also the rotors Configuration of Magnetic Teeth appears to move at a faster RPM than stanleys alternator because the Rotors Magnetic Teeth are closer together in my setup while in stanleys the rotor is bigger so they're further apart. My alternator simply can't compete with stanleys because of this. So this makes me wonder what will my 5 cc's turn into if i was to add an alternator like stanley used..
any information or pictures of stans alternator will be appreciated, OR even what type of car or tractor carries such big alternator.
Also my 12 tubes being 6 inches long with a 1/16th gap may even further restrict gas flow from my tubes while holding the small geo alternator under a load. What if i not only replaced my alternator with a bigger one but replaced the tubes with a bigger gap as well, could this cause Smoother gas flow and cooler water? i'm seriously thinking i have way to many tubes, my gap is very small.
i was looking into the joe cell last nite, i priced several pipes and tubes that could work, 100 to 200 bucks a pop is clearly not the way for me! The only think i can think of is i am simply using the wrong tube setup,,, Could anyone bring forth the tube specs stanley was using?
I see the alternator on the buggy, i dont really think he has anything resonating, i think he is using lots of amps into the cell to make running the car on water "possible." Anyhow, thats the route i'm taking,, the possible route. I feel that whatever stanley was doing on that buggy is getting clearer and clearer for us all, we all see what is going on learning new things day by day. I dont think we will ever learn what he used as a fuel cell but only wonder..
If that jackass that was hiding his car could tell us a few things we would be good to go, but thats not going to happen,, gruuu. The goal now is to find the right Cell setup with the right alternator and then you have it! we already know stan ran a car on 5 volts 2 amps pulsing the rotor, so we have that estimite, also we're lucky to even have a picture to help puzzle all this together.
So for me, its a new bigger alternator and a New cell, Time to party and leave the old cells and alternators in the past.
« Last Edit: June 03, 2008, 01:16:39 am by hydrocars »
hydro
« Reply #14 on: March 31, 2008, 06:26:36 am »
incase any of you must have missed it, in the last picture you read that stan used a series cell to gain more gas.
« Last Edit: March 31, 2008, 06:36:46 am by hydrocars »
hydro
« Reply #15 on: March 31, 2008, 07:41:41 am »
im just not buying that series cell stuff, i tried it several times with bad results, this was with tube cells though..
However, i did add a pinch of salt,, OH BOY,, now i can see mud all over the top of my water,,,, the first time i've really used an additive... after seeing what salt does it somehow gives better production without loading down the driver motor... Thats ODD how it does that..
after reading stanleys patent on how to remove the gook from the water i can only think,, you shouldn't have that much gook.. well after running test with salt i had so much gook i couldn't even see my cell,, its like a brown cloud that looked like fungy or summin.
maybe with salt i can add more cells? From past test me and stevie has made, the types of water in this world is much, i know there has to be well over 30 diff types of water, even stevies rain water was different than mine, this leads me to think stan was adding something,, I KNOW and i dont care, thats just what i think after seeing the test results and how the gas production went up and the amperage basicly stayed the same.. I think i'm on to something here with salt.
whatever does the trick is what im interested in..
