Author Topic: How Stanly Powered His alternator  (Read 52031 times)
« Reply #152 on: June 06, 2008, 18:44:56 pm »
oh so  the vic is that e-z no problem
i think 2 amps is good like in water power 4 But i have another design that may lower it to 1/2 amp
« Reply #153 on: June 06, 2008, 20:06:30 pm »
yeah the alternator way was a demonstration piece and most likely his first version but in every lecture video he stresses on the vic....that is where all the mystery is at.....soon i will be getting all the necessary pieces of his rotary method and be able to put myself at the front line for figuring things out....i have almost completed the xogen method.....somethings are backordered though....but have you tried different frequencies with your alternator?? by frequencies i mean palying with the speed (rpms) of your alternator by using different pulley methods.....maybe you can try 1:1, 2:1, 3:1, or whatever adn see what gets the most output....since your cell is quite large you might want to try and find a frequency that would run through your tubes best.
hydro
« Reply #154 on: June 06, 2008, 20:51:17 pm »
Stan Didn't use additives. Stan didn't use pure DC, Stan got just a bit more from his cell than you normally would under normal Electrolysis using Unstable DC such is what the alternator offers, He was able to Produce just enough to get the job done meaning he Beat Normal DC with Unstable DC, in return The gas output is proven unbeatable but also still nothing Drop dead, only possible to boost the production this way which boosted it enough To make it possible. When stan talks about resonance he is NOT referring to the water!
The truth is all around you, The gas directly from the top of the water is junk. Learn to run an engine on around 600 cc's a min like stan did, then you will be doing something, you will start understanding what is possible and what is not, you will start to see what KISS means which is the method stan used. The vic has nothing to do with water at all, large amounts of gas just isn't needed because of the vic and what it does, and its flawed in the patents, anyone with good iq can pick the flaws out and make it work.
Who told you Stan Produced Enormous amounts of hydrogen? Why do you think that was? When stan told you his gas production and left numbers behind, you fail to prove him lie? Why? you believe what you see and shouldn't, there is only 1 lie i've known stan make, and turns out it really wasn't even a lie. Stan was Magic, learn his magic way that creates confusion, you thought the patents would just lay this technology into your lap?
I think i just said alot, enough that you can figure this technology out if you really want it. "do you really want it?" ask yourself that. you would better this technology if you do not look over this post.
jbhuffinstuff
« Reply #155 on: June 07, 2008, 02:57:56 am »
in stans work he described resononace as deterant to keep you from find what he was really doing their is a resonance involved in his work but their is much more to it he was destracting you away from a specific wave form it isnt the resonance that makes his process work it is the waveform resonance is a by product   when you find the wave form  that taps into the true potential of water you will be ammased at what you can get for nothing into it   as of  now i have never been able to find a  wave form to match it  it might not even have been what stan was doing it could be something totally different  but it works that all that matters their is more than likely an infinate potential to it which i have been exploring this is one believeable example
i have a tube cell  9 tubes  six inches long with it  using the right type of wave form  i can get  over a liter a minute at 4.4 volt and .28 amps  if i mix the 50% distilled with tap water i can get a liter  for as low as 4.4 volt  .01amp
 i have had problems with the wilson person and have caused problems for hydro and his site and have decided to  give up on the forum thing for good i  did ask to delete my account   and i am done with public forums for good  i still plan on working on hydrogen privately  and will post some stuff on youtube in the future  on how its done  after i finish with my small engine/ go kart  project in the next few weeks
hydro im sorry for the problems with everything
hydro
« Reply #156 on: June 07, 2008, 03:40:44 am »
i know what you mean topsy,,, its ok to stay low and give tips to the ones that can understand them.. Its clear the ones that understands this technology was picked on and threatened into leaving the internet for their own good.  But the thing is someone will stumble upon it soon. As far as stanly gaining resonance with water,, no he didn't, if your producing lots of gas with high volts low amps then this is something stan didn't do therfor if you accomplish that then it is you that deserves the credit for that, not stan. Water does have resonate freqs, everything does.
let the destractions continue to work, i'm using it for my benefits ;)
jbhuffinstuff
« Reply #157 on: June 07, 2008, 04:12:30 am »
when you find the wave you just keep put  circuits in parallel each circuit is a liter plus  i just broke down my cell and insulated the electrodes in delrin plus put a mushroom type cap on each to make it push out  a few  big bubble instead of millions of small bubble   and am putting 5 circuits in parallel to run my 5.5 briggs motor  for my go kart  should give me roughly 7 liters a minute for  4.4 volt and 2amps  but that is a guess as of this moment cause im not sure if the current leakage will drop my voltage or in crease my production i am hoping for increased gas
also once you hit the proper wave form you will find the true reason their is a electron extraction circuit with out it when you turn your cell of it will turn into a shorted out battery and generate massive heat  which start to melt my pvc  cap were my tubes were  mounted to  if you think about it what use is it to take a little energy out for a 40 watt light bulb their is a totally other reason behind it that why stan and dingle have them  and im putting one in to
« Reply #158 on: June 07, 2008, 05:30:10 am »
Does any body know how to get a rotor to draw 2 amps at 5 volts.
The rotor on my delco remy draws only 0.6 amps at 5 volts. There is a huge difference between .6 amps and 2 amps. the rotor magnetic field will be greater because of the greater amp flow,
This is confirmed by eye witness Rea o Neill from dublin institute who visited stan meyer. [According to O Neill's eyewitness testimony page 82 and page 93 of the report.] I think in the independent testing report. Stan also calls out 5 volts 2 amps in his video so i dont buy it that he mislead people or lied or deliberately confused people.
Either Stan's alternator rotor was modified or he sourced an  alternator that actually did draw 2 amps at 5 volts factory made off the shelf.
Any advice on this would be highly appreciated.
« Reply #159 on: June 07, 2008, 05:45:03 am »
I believe virtually every eyewitness claimed the device was OU. That was why there was even a documentary made about him. He also claims 7 liters per minute in his testing doc.
Also please read the intro document on page 8. Critical Review of the Available information regarding claims of ZPT, OU etc etc
Stan is the only device which is claimed to have Accurate observation of phenomenon. Virtually every other OU device is bunked.
Also read Admiral Griffins concern on page 96 : A substantial number of UK scientists and engineers regard WFC technology in breach of first and second laws of themrodynamics.
In case anybody missed, this doc can be downloaded at: http://aquapulser.com/research.html
And there are too many eyewtiness who also calim the cell was cool to touch after 20 mins. (Wireless world article)
First of all when i pump more than 10 amps to my cell i notice it gets hot pretty fast. How was stan able to pump 40 amps at 12.5 volts DC and the cell remained cool????
There is something very fishy going on here or there is a lot stan left out form the rotor 5 volt 2 amp draw to how the cell stayed cool even though 500 watts of power is being pumped into it.
