Author Topic: Theory - Coil Calculations to Restrict Amps (CONFIRMED)  (Read 25407 times)
Re: Theory - Coil Calculations to Restrict Amps
« Reply #32 on: December 31, 2012, 18:52:50 pm »
In my testing when I achieve Parallel Resonance, the water type doesn't matter because it seems the cell itself has no effect on the resonance. I know that may sound strange to some, but I can disconnect the cell and place a resistor in its place and still get the Parallel Resonance. The resonance seems to be taking place between the two coils!
Agreed.  That is my observation also.
TS
« Reply #33 on: December 31, 2012, 19:47:58 pm »
Show the whole circuit please... you should get higher spikes.
« Reply #34 on: December 31, 2012, 20:05:13 pm »
8XA Circuit
« Reply #35 on: December 31, 2012, 20:21:36 pm »
are you using a battery or a power supply?
« Reply #36 on: December 31, 2012, 21:03:58 pm »
The circuit is exactly as you see it in that layout.
« Reply #37 on: December 31, 2012, 21:25:12 pm »
You should use power from a steady source such as a battery or large capacitor.
« Reply #38 on: December 31, 2012, 21:26:25 pm »
huh???
« Reply #39 on: December 31, 2012, 21:28:26 pm »
yes the harmonics are vastly different between these two ..  ::) you can use a 555 timer and get power from a battery , I'm not an EE btw.. so don't trust me that much.. if you have parts lying around try it for yourself.
