a4 thorzpower: regarding the 3 phase output multitier device notice the physical divider on end view.
vanes similar to spitfire brazer of 1970 for induction of air/mapp gas swirl.
AI first physical solution is to twist nonconductive pipes as rope strand,
AI second option was option of twisted trilobe / hexlobe divider inserted into the
non conductive EPG spiraled tube.
See attachments:
It appears Meyer may have opted for second option. If his terminology is being interpreted correctly, then Meyer was showing it as it was- physical spiral divider that ran the length of the copper tube or if not, perhaps
a short physical divider vane may be all that is needed to set up the vortices within the spiral tube.
The EPG cross-section is clearly showing a physical divider which sets up the rotating fields as mag gas
traverses the containment tubing.
q4 sandia24 : do you think in the three phase gega device that each mag gas vortex strand was one phase ?
