Here's something else I've been considering for a while and has recurred to me last night. The water doesn't actually need to be in direct contact with the SS does it? I mean, the whole point of this SM's design is to use high charges to pull apart the water molecule, like using magnetic forces. With the water actually being a lossy dielectric, couldn't we just isolate the SS tubes from the water with some sort of sealant; urethane or epoxy or something? This would allow a higher voltage charge on the cell, prevent electron transfer to the water, and create additional resistance in the circuit.
This would possibly produce the same effect as the oxide skin, except be more permanent.
Has anyone tried this?
TS
I do not post as often as I did in the past but here we go. I shared your thoughts a while back and searched for info regarding surface protection and metals with higher surface resistance to oxidation as my main focus was on voltage dissociation. But then I listened to the radio show with Stephen (that you can locate on Tony's page). Stephen mention that the electrodes are part of the efficiency, he even used the word over unity. What happens is that the process itself - energy charging the metal and oxidization - releases stored energy in the form of electrons. These electrons now become a part of the surplus energy within the dielectric and hence more energy now becomes available. We can also speculate about the vacuum energy found when the hydrogen atoms becomes ionic species, but that is another debate on its own. So, what Stephen is telling us is that the process use the energy found in the metal, so using protection or PVC on the metal surface limit the total efficiency.
This changes how we view the process as a hole. The iron oxides that we see is not from an acidic environment, but electron surging similar to standard Brute Force Electrolysis. We might even say that there are two process going on: 1'st is the High Voltage and Resonance (fundamental forces and molecular swing) and 2'nd we have the electron collision from Faraday's learning.
Voltage on its own is very hard to get started, so therefor we have the soft start ( charge build up aka, depletion layer) and we have the electron collision.
It is a trick - yes, a trick, but non the less there. So instead of looking at it as a way of insulating the electrodes, look at it as that the electrodes are part of the system. Now of a sudden we need to change the system - just like Meyer and Stephen found. More free floating radicals (metal ion's) will pick up a charge and allow more electrons to flow, this is similar to straight DC run away effect. He add the steam reformer and filtration so he could keep the water clean and control the dielectric PH levels, temperature and insulation property (which needs to be high for amp restriction).
I hope this info helps you a bit.
Regards
Oneminde
