Author Topic: cell setup 1  (Read 2075 times)
cell setup 1
« on: February 21, 2012, 10:37:57 am »
This is the cell that I`m curently experimenting with
this setup consists of 4 different cells and experiments were done to each one individually for diffirent capacitance value purposes. Cells were encased in pvc and it was designed so that water can circulate through in between the exitors.
the 4 cell specs are:
1) 6" long 2mm gap
2) 3" long 2mm gap
3) 6" long 1mm gap
4) 3" long 1mm gap
As a design I also included some extra tricks that I did not have time to play with yet. I also designed a way to force mechanical(soundwaves) in the cavity. Led/Lazer light can also be injected in the cavity using fiberoptic. However these are only unneccessary features that at this point are not worth experimenting with before we sort out the basic polarization/resonance processes.
HM
« Last Edit: February 21, 2012, 11:06:35 am by hydrogenmask »
