Author Topic: Goldsworthy Gurney 1826  (Read 4747 times)
oddball
« on: March 06, 2008, 16:17:01 pm »
First discovered by the Cornishman Goldsworthy Gurney in 1826, limelight was sometimes called the Drummond Light, because during a survey of Ireland Thomas Drummond found that when he used limelight with a parabolic reflector he could signal 95 miles from Antrim to Ben Lomond. In the early 1820s Gurney had invented an oxygen-hydrogen blowpipe, which produced an exceedingly hot flame, and he began experimenting with various materials to see what he could do with it. He discovered that when he played this flame on to lime, especially with a little added magnesia; it produced an intense white light. Today the simplest material to use is a stick of blackboard chalk; when introduced into the oxygen-hydrogen (lame, it quickly begins to glow; and within a few seconds the light becomes dazzling - not as fierce or blinding as an arc light, but nevertheless extremely bright. As with the arc lamp, there are some problems, because the lime is gradually burned away, but limelight is much easier to handle than an arc lamp and it needs no electricity. By the 1860s limelight had become the standard for stage lighting, especially for the sun and for follow-spots - hence the phrase 'in the limelight'. Limelight was used in London theatres for fifty years, and to this day spotlights in theatres are known as 'limes'.
(http://upload.wikimedia.org/wikipedia/en/0/02/Limelight_diagram.PNG)
So this tends to pre date Yule Brown by over 100 years 8)
  • Look out for the M I B
Re: Goldsworthy Gurney 1826
« Reply #1 on: March 06, 2008, 17:00:41 pm »
w00t
now we can make realy realy expensive flash light`s guys  ;D
Mr Browngass
oddball
« Reply #2 on: March 08, 2008, 20:05:27 pm »
Any idea how he made the hydrogen gas?  Have you checked out
http://www.knowledgepublications.com/
check out the Wood Gas Stove
Tim
Interesting site that good books maybe!
I think Goldsworthy used electrolysis and sacrificial metal to generate the gas.
I was watching an old episode of "What the Victorians did for us" about the entertainment industry and it demonstrated his principals and they ignited balloons full of the gas.
First a balloon of Hydrogen loud bang then hydroxy booooom! ;D
He first tested the gas in a torch heating and cutting metal etc.
« Last Edit: March 08, 2008, 20:08:21 pm by oddball »
