Author Topic: How to build the vic tried and tested  (Read 38374 times)
« Reply #112 on: August 08, 2012, 00:14:59 am »
The impedance of a resonance fed in parallel is huge theoretically infinite and is defined by the Q factor.
If you apply for say 40kv at 1ma and the tank have lets say 10 amps recirculating its clear that the XL is 40000ohms
and the Q is the relation of the input current to the recirculating current.
if you get 1 amps divided by 1ma you get Q factor of 1000
giving an impedance saw by the source as a 40MOhm resistor.
in series circuit the voltage will be the initial voltage(t) times the Q...
