Author Topic: Stanley Meyer Photo Album and Index Mystery Part  (Read 1753 times)
« on: June 18, 2011, 21:03:18 pm »
I color inverted and sharpened to bring out the detail on the IC's in this Stanley Meyer circuit to aid in its identification.
What is its function so that a proper name can be assigned? I am looking for a patent number and block diagram.  Control circuit?
« Last Edit: June 21, 2011, 14:12:34 pm by jim miller »
wrong, that is not the electrostatic filter array circuit board
it is one of the figures in the control and driver patent
Re: Stanley Meyer Photo Album and Index
« Reply #2 on: June 21, 2011, 06:20:42 am »
Jim. My new internet provider did not work out. I will be installing an Antenna tower for my new local internet provider and it will work out!!! So I am delayed yet again. I seen lots of photos and look forward to seeing lots more. If you are the owner of the items in the photos I can understand your presence. I can see clearly what was is missing. If the owner of this stuff is here, Id like to know. The next time I put true efforts in, It'll be what stan done. Stan found the frequency of water and I too did with my old alternator setup. It was much like a trickle charge that danced with harmonics. however it isn't what comes from the water you should be looking for. There is something missing from the picture that nobody see's, and stan isn't talking. The key may not be what you thought it was. On the atomic level, it is what it is and it is just that, It runs on water in the end.
« Reply #3 on: June 21, 2011, 11:20:49 am »
"however it isn't what comes from the water you should be looking for. There is something missing from the picture that nobody see's, and stan isn't talking. The key may not be what you thought it was. On the atomic level, it is what it is and it is just that, It runs on water in the end. "
Fascinating. When I first began building basic chemical electrolysis cells (ie koh doped) I was told the size of the bubble is thought to indicate what might be produced, ie large bubble more oxygen ,tiny bubbles is what was aimed for.....
So in the riddle, whats missing in the picture nobody see's thats the key may not be what we thought it was..
