Planning on just 2 chokes, or split secondary on the first attempts. I will call the secondary as choke A and choke B for reference.
Each Segment consists of 80 turns of 24 awg wire. 4 segments per choke coil.
Choke A: 320 turns total, inductance 44.5 mH
Choke B: 320 turns total, inductance 46.4 mH
Give or take some for the cheap meter I use.
I am planning on using a 1600 v 0.1 uF capacitor on the secondary side.
Blocking diodes are 600 volt, 15 amp rating.
(Edit: Voltage rating should be plenty as the water will conduct with anything above 1.2 volts)
( In theory the only voltage reading at the cell is the voltage drop of the water itself, the rest is recycled)
Target AC frequency is 1668 hz.
Anything off this frequency will result in XL killing the voltage, very low Q, and or, loss of efficiency in cycling.
I may cut the secondary capacitor in half to target a higher frequency of 2359 hz.
I still need to complete the primary winding (tune to primary cap for above freq. aka tank circuit) and complete the tube in tube cell - lots of machining on this still.
warj1990
