Author Topic: What if....which part would you choose?  (Read 5484 times)
Re: What if....which part would you choose?
« Reply #8 on: May 24, 2011, 10:30:42 am »
yea ...allways wandered why Steve Meyers  only has an empedance network card in his patent with the primary field not explained.
« Reply #9 on: May 24, 2011, 11:29:20 am »
I am happy to read that i am not the only person with the same mindwaves... :)
You all made good suggestions.
I ll go with Mina's theory in this case.
It must have been something out of side...
I have attached a picture made by Dynodon. He published that picture on this forum earlier this year.
Have a look inside the wfc of Meyer.
Ever asked yourself why he made that strange "cup" at the bottum?
I suspect that there was a special module in the middle...
Agree?
« Reply #10 on: May 24, 2011, 12:13:32 pm »
Hi
in that picture steve posted of the wfc, in that picture bottom centre - anyone know what are the  function of the 5 (electrodes ?) which are vertically aligned may be for or might they have been to detect the water levelor something else?
« Reply #11 on: May 24, 2011, 14:06:44 pm »
Another possibility
There is a short video segment at the end of the long dune buggy video (9 minute version)
where Charlie and Stan Graumlich  are assisting the tightening down the top of the reaction chamber with the comment "That'll about do it" prior to the run down the road.  Were they puting in a critical part or just checking prior to buggy run that all the seals were tight?
« Reply #12 on: May 24, 2011, 16:04:50 pm »
Another possibility
Which video do you mean, Jim?
« Reply #13 on: May 24, 2011, 16:35:54 pm »
Interesting thread.
This means we don't understand fully Meyer's work. But he had very good ideas.
« Reply #14 on: May 24, 2011, 16:41:31 pm »
i think the recessed cup in the resonant cavity is to help prevent the pump from sucking in gasses.. Stan is circulating his water.. If the return was at the same height as the outputs of the tube cells you will be more likely to suck the fuel gas into your  circulation pump...  If Stan did have a part to remove for disabling functionality it would be something with quick and easy access.. not something you need to take a lot of bolts off to open in my opinion.
« Reply #15 on: May 24, 2011, 22:55:31 pm »
The cup is brown colored. I have seen that happen in my cells. Nothing special. But in the middle there is a white circle..... Why is that not brown?
Maybe because something was put on that ring?
