Author Topic: spliting water using magnetism  (Read 5220 times)
« on: February 20, 2008, 09:04:37 am »
Hi all,
I came across this patent on the net. Do you believe to this stuff? For me sometimes I do and sometimes I dont. Do you think this is worth a try ?
efficiency 20 times over faraday  :o
116 cc/s with 84watts  :o
« Last Edit: February 20, 2008, 09:08:47 am by hydrogenmask »
hydro
Re: spliting water using magnetism
« Reply #1 on: February 20, 2008, 11:16:05 am »
actually yes, but in that patent they're using NAOh to help the water take on magnetics. the patent is basicly telling you that the water is magnitized by voltage. this makes you think magnetic however magnetics is not whats used here, it is like a magnetic force from a coil, they call it potential magnetic and I call it electric fields, however you get this from coils.
the patent said that it produced 10 to 20 times more gas then normal electrolyis, however they used NaOH. what i have been trying to show everyon is how to get what they call potential magnetics, which i call it electric fields, also i have to produced atleast 10 times more gas with using this type of electric field without the use of any NaOH.
Now i understand why bob used NaOH, it helped the water become effected more rapidly. but with harmonics from the alternator you dont really need NaOH if you do it properly.
« Reply #2 on: February 20, 2008, 12:08:20 pm »
quoted from above patent
"under the function of the potential magnetic field formed by the coil current which is generated by the electrodes"
If I am understanding correctly the coil are the electrodes themselves. Therefore is this cell only run by a straight dc voltage ?
« Reply #3 on: February 27, 2008, 08:55:23 am »
that looks realy cool
