Author Topic: Meyer-Photogrammetry Inverted 7 Bracket Dimensions I7B  (Read 1017 times)
« on: March 08, 2011, 01:58:01 am »
A scaled drawing of I7B Inverted 7 Brackets from the Demonstration Unit
Total Length of I7B approximately 3.5 inches long.
1.0 inch "foot" drilled for attachment to bottom end cap
1.5 inch bent at 90 degree angle
0.625 inch attached to outer tube
These measurements from an engineering blueprint. Stan's actual implementation was different with a lot of custom bending and fitting to make the I7B brackets have sufficient clearance to avoid touching the ETP Electric Transfer Plate
« Last Edit: April 11, 2011, 14:40:18 pm by jim miller »
