Author Topic: Buck's Cell  (Read 4267 times)
Re: Buck's Cell
« Reply #8 on: March 02, 2008, 02:35:27 am »
(http://i75.photobucket.com/albums/i283/carbednotch/carb001.jpg)
This Propane carb has annular venturi boosters which is just how I want it.
I will remove the return springs on the throttle plates and secure them WOT.  Completely opening the intake.
I will regulate the RPM of the engine with a valve that regulates the A/F ratio through the mixer. (carb)
Inside the vehicle will be a timing adjuster connected to a MSD digital ignition.
(http://i24.ebayimg.com/03/i/000/da/ef/0d1c_1.JPG)
(http://i17.ebayimg.com/02/i/000/da/ef/0c18_1.JPG)
A little clean up and this thing is ready for some action.
(http://i75.photobucket.com/albums/i283/carbednotch/alt3phase003.jpg)
(http://ionizationx.com/index.php?action=dlattach;topic=212.0;attach=591;image)
This is the alternator I'm using.
« Last Edit: March 02, 2008, 02:37:39 am by CarbedNotch »
Re: Buck's Cell
« Reply #9 on: March 02, 2008, 03:14:30 am »
Technocarb $800
Re: Buck's Cell
« Reply #10 on: March 12, 2008, 04:18:46 am »
8amp dc
 ;D   Have I ever said I love bubbles?
Re: Buck's Cell
« Reply #11 on: March 12, 2008, 04:30:28 am »
Here is how the electrical part is going.
(http://i75.photobucket.com/albums/i283/carbednotch/alt003.jpg)
  • OO-Rah!
Re: Buck's Cell
« Reply #12 on: March 12, 2008, 05:27:16 am »
doesn't look like it will be too long before I see your's fired up. looking good
Spike
Re: Buck's Cell
« Reply #13 on: March 13, 2008, 16:26:24 pm »
Spike
All I have to do is figure out this diode bridge to get the alt to put out voltage.
Today I'm going to radio shack to get a PC board so I can start putting my circuit together.
 :D
I'm very excited to see more wonderful bubbles.
Re: Buck's Cell
« Reply #14 on: March 25, 2008, 15:13:06 pm »
I have decided that I want to increase the gap of my electrodes from .024 to .076 and this time its 316 from 304
I ordered up a set of 316 tubes so I'm going to modify my cell. Also the lids (top and bottom) are a PITA to seal up. You have to tighten the wing nuts really hard. I need to get a proper router bit and re-do that part as well. I have found a CC measuring device or container, call it what you want so soon i'll be measuring my output as well.  I'm going to first test the output of my cell now and then after my modifications or upgrades soon.
« Last Edit: March 27, 2008, 20:05:12 pm by CarbedNotch »
Re: Buck's Cell
« Reply #15 on: March 27, 2008, 20:17:22 pm »
I got these tubes to build my second cell. I think the small gap in my first cell was restricting air and water flow.
Stainless T-316
Seamless Tube
1" x 0.049" x 0.902"
Cut to: 60"
Stainless T-316
Seamless Tube
0.75" x 0.049" x 0.652"
Cut to: 60"
