Author Topic: alternator setup  (Read 17728 times)
Re: alternator setup
« Reply #40 on: February 14, 2008, 06:19:39 am »
i am using variable speed switch from a hand driller, so I can vary the speed of the motor.
Can you elaborate a bit on this. I'm having trouble imagining it.
« Reply #41 on: February 20, 2008, 16:01:24 pm »
I took apart a broken handdrill wich had a variable speed switch and hooked it to the drivemotor instead ;)
  • OO-Rah!
« Reply #42 on: February 29, 2008, 21:43:36 pm »
hydrogenmask, Are you using your computer as an O scope. And if so, Where did you get the software and leads. Thats a pretty neat setup.
Thanks
Spike
mrgalleria
« Reply #43 on: May 01, 2008, 08:28:33 am »
Aloha,
Here is my alternator set up, 2 Hp 3450 RPM motor.
Bill
« Reply #44 on: May 01, 2008, 13:51:12 pm »
hi Spike,
sorry I missed your question. The Oscope is a 40mhz pc based oscilloscope. I bought it from ebay, and comes with the probes.
http://www.darkwire.com.au/html/dso-2090_usb.html
hmask
  • OO-Rah!
« Reply #45 on: May 01, 2008, 18:32:55 pm »
Hmask
That's alright, I found it there myself. It's a nice setup. But the last couple of months I've been to broke to pay attention anyways.
Thanks
Spike
shovel52
« Reply #46 on: August 12, 2008, 06:07:47 am »
sorry to change the subject I am new. Just curious about using an ac motor for the alternator. Is this just for bench purposes? How about on the automobile?
  • OO-Rah!
« Reply #47 on: August 12, 2008, 06:55:43 am »
shovel52
This is just for bench testing. So that you can run your cell from an alternator.
Spike
