Author Topic: 2008 water burns baby!  (Read 9422 times)
hydro
« on: January 22, 2008, 12:11:22 pm »
it has been found that a wfc connected to an injector from a 1996 dodge neon can can make water burn.
the hydroxy in the line connected to the injector contained a small amount of water, at first the water was a pure stream but as the water started to run out a fog appeared from the tip of the injector exiting from the 4 small pinholes in the tip of the injector.
a white misty cloud formed containing Hydroxy mixed with water mist. notes where taken on the hydroxy burn spurts from the injector without the use of water, it is clear the invisible mist was explosive but did not appear to burn only pop.
the added water in the hose from the later test showed that when the water was in a pure squirt form from the injector it puts the flame out. however, when the water started to run out the injector started to spit then mist a white hazy cloud into the air. the Cold water mist mixed with hydroxy at the injectors output "will" result in a flammable water mist.
now the question is, how do you get the right water mist mixed with hydroxy? stans car appeared to have a water pump inside his fuel cell on his dune buggy. i am thinking you run the hydroxy threw the bottom of a water tank while rapidly shaking the water into a bubble form, then feed to the injector. the injector will mist when the water is running out, or not pure. this leads me to believe you need bubbly water of some sort that has been mixed with hydroxy some how.
if you know of or find the video where he has a Motor hooked to a shaft which is going into his cell please post that picture.
this is not found on the internet, this is test i have tested.
good day, OH, i really hope you save this information somewhere.
« Last Edit: January 22, 2008, 12:38:50 pm by hydrocars »
Re: 2008 water burns baby!
« Reply #1 on: January 22, 2008, 15:57:58 pm »
Hi Hydro,
You had a productive day!
What i read between the lines is as follows:
The water in my wfc is completely foggy of the hydrogen and oxygen which is in there.
So, what you suggest, is to mix the gasmix from the top of the wfc with the water inside the wfc at the tip of the injector.
We better make a small wfc close to the injector.
Like the VIC container.
Hmmm let me think about this. What happens if you do electrolysis in a container completely filled with water.
Perhaps make it hot till it boils...watervapor. You get a mix of watervapor and hydroxy
You can add more power or less power to the electrodes to get the perfect mix
hydro
« Reply #2 on: January 22, 2008, 16:29:42 pm »
from what i understand with the proper mix very little hydroxy is needed. the mist is very odd and crucial to get, i would like to look into a cool mist humidifier to see how they work and to see if they provide the mist i am looking for.
when you get the mist, you will know it! the water molecules appear to float in the air.
mzk
« Reply #3 on: January 22, 2008, 18:00:11 pm »
Just few questions.
Is this external injector (i mean outside ICE)?
Second- how do you ignite the white mist? Using spark plug or other kind of flame?
And to make it more exact- you pump your injector with the misty water (on the top of the water fuel cell)?
Thanks in advance!
« Reply #4 on: January 22, 2008, 18:38:21 pm »
wow, thumbs up guys, this is huge, this all goes back to that video that stanley meyers made when he adjusted the carburetor and said he was adjusting the burn rate of the hydrogen.  i think if you pair this with some plasma spark technology to ignite this for sure in the cylendar,  this will be what we are all looking for.
    • WaterfuelForAll
« Reply #5 on: January 25, 2008, 09:30:05 am »
Hydro
WOW! This is exciting!  :o
« Reply #6 on: January 27, 2008, 04:10:31 am »
hey hydro,
I forgot to mention.  I know that the injector that you are working on is out of a dodge neon, if you still do have this car, there is an easy way to adjust and tune for your engine.  you should check out megasquirt electronic fuel injection.  I believe that the neon's have the same 4cyl engine as the mitsubishi eclipses.  this is the 4g63 engine.  this is mitsubishi's most famous sports car engine.  but besides the history.  they have many aftermarket parts for this.  this Megasquirt computer may be pricy, but the tuning of your engine can be done completely through a laptop computer.  good luck again.
Badnova
« Reply #7 on: February 01, 2008, 03:40:32 am »
I had also been thinking about misters.
If you add a pond mister to the top of your cell it should add a lot of water mist to the hho gas before it is added to the engine.
Here is a link to a pond mister. http://www.clearpond.com.au/go/our-products&prodID=8214&catID=225&subCatID=39&mode=productDetails
You can get it with a float so that it would float on the surface in a cell
Shodan
