A clean and green environment is a human right
Home
Help
Login
Register
Ionizationx: a clean environment is a human right!
Engines On Water
How to run your car on hydrogen or water
Waistspark removal schematics for 1 cylinder engines
Print
Pages:
1
Go Down
Author
Topic: Waistspark removal schematics for 1 cylinder engines (Read 3248 times)
Login to see usernames
Administrator
Hero member
on:
September 07, 2010, 21:50:31 pm »
Hi,
I found a really simple, but probably the most effective schematic if you need to remove a waistspark on your engine.
Logged
hydrofuelincanada
Guest
Re: Waistspark removal schematics for 1 cylinder engines
Reply #1 on:
November 22, 2013, 03:53:08 am »
How will that remove the waste spark ?
Neal
Logged
Administrator
Hero member
Reply #2 on:
November 24, 2013, 10:19:29 am »
Quote from: Login to see usernames on November 22, 2013, 03:53:08 am
Neal
I used two gears ratio one on two.
Put the magnet on the gear that turn two times slower then the crank.
Done!
Logged
hydrofuelincanada
Guest
Reply #3 on:
November 26, 2013, 03:47:52 am »
Ah okay, gotcha, I thought you had an electronic circuit to cut the waste spark.
Neal
Logged
Print
Pages:
1
Go Up
Engines On Water
