Author Topic: ALTERNATOR  (Read 47055 times)
Re: ALTERNATOR
« Reply #104 on: September 06, 2010, 15:07:49 pm »
Yes steve hopfully in the end of the day today i will get it to work. Cross your thingers too ... =)
I tried to make the pulse transformer on the ferrite core (antena rod) not very gud i think is because the permeability is low, i´m trying to figure out another way easy with no need to build more 2 driver circuits with also two new isolated power supplies...
 if anyone can help, basically i need to send +- 15 v to the igbts gates at 50 ma i will than use some zener to limit the voltage... The main problem is that both igbts must be isolated from ground and each other.,.
thanks
Re: ALTERNATOR
« Reply #105 on: September 06, 2010, 16:56:01 pm »
This is exactly what i have here exept that i have 4x cd4017 divide by 10 and a 4 way switch giving me range from 150khz to 10 hz
The circuit as it is give you a range from 1khz up to 150khz, if you change the 1nf capacitor by a 10nf capacitor you will get from 100 hz up to 15khz ...
THERE WAS ONLY ONE ERROR IN THIS SCHEMATIC, THE POSITIVE GOING TO THE FIELD COIL DON´T COME STRAIGHT FROM THE BATTERY BUT FROM THE SWITCH... !  NOW IS CORRECT!!!!!!!!
« Last Edit: September 06, 2010, 18:07:46 pm by sebosfato »
Re: ALTERNATOR
« Reply #106 on: September 06, 2010, 22:17:20 pm »
I HAVE JUST ATACHED THE FIELD COIL AND ONE OF THE PHASES ON THE PCOSCOPE AND I NOTICED THAT DOES NOT MATTER THE FREQUENCY I PULSE ON THE FIELD COIL IT WIL AWAYS BE 120HZ ON THE PHASE COIL...
vERY STRANGE ISN´T ?
I´M THINKING ABOUT CREATING A SIMPLE FREQUENCY GENERATOR TO USE WITH THE MOTOR DRIVING THE ALTERNATOR TO BE ABLE TO CHANGE THE RPM... WHAT YOU THINK ABOUT?
« Last Edit: September 06, 2010, 22:35:54 pm by sebosfato »
Re: ALTERNATOR
« Reply #107 on: September 07, 2010, 14:50:51 pm »
So, guys i would like to hear more about you all that is reading this thread.. what do you think about the voltage perform work theory that i came up with? Now that some time passed, i think that you are now more able to visualize what i´m saying. That stan talked about voltage causing self ionization of water and than performed work separating the charges on the dielectric using no energy from the conventional current... and that than discharged those ions generating electricity witch was applied instantaneously to the resonant charging choke and that by transformer action cause the voltage to build up even further! What do you think about the fact that the movable wiper coil was to be the primary that induce on the "secondary" resonant charging choke voltage, and for that reason it should be able to change its inductance value to perfectly tune to the dielectric and resitance proprieties of the water, and to get the rioght ratio between voltage and current, to maximize the resonant effect.
Please feedback=)
Re: ALTERNATOR
« Reply #108 on: September 07, 2010, 15:11:02 pm »
I have to say that, stan was not a stupid he was very speciaslised scientist in contrary to what seemed, because he knew that anyone with enough knowledge would be able to understand and repeat what he was doing, the way he hided his secretes was a tentative to protect him against those with knowledge in the prior art;;; I aways knew that the knowledge was the way... I´m not a chemist not a physicist, not a mathematian, i´m a musician and a scientist, i studied so hard in this 5 years about hydrogen, water, energy...  that i can tell you, i don´t find anyone not even in the university that speek my language, they are aways busy with their lifes, i believe those are not scientists, they don´t even want to understand...
The only people witch can understand what i´m saying are you...
Re: ALTERNATOR
« Reply #109 on: September 07, 2010, 15:59:55 pm »
Thats the good thing of a forum.
But still...
Its always hard to follows the steps of other people.
Seb..what are your results, yet?
Have you tried to get voltage of the wfc/ions back into the circuit?
Like Warp and i did with the alternator? Charging the primary(rotor) with use of the wfc?
Re: ALTERNATOR
« Reply #110 on: September 07, 2010, 17:05:19 pm »
i JUST NEED TO FINISH ONE MORE OPTOCOUPLER DRIVER CIRCUIT FOR THE IGBTS AND SOLDERING EVERY THING... I´M GOING TO BE ABLE TO DO SOME TESTS IN THE END OF THE DAY...
i WILL TRY IT STEVE...
thANKS
Re: ALTERNATOR
« Reply #111 on: September 07, 2010, 22:09:39 pm »
seems most lack the mindset to approach such knowledge.. like you said they are to busy... in our minds we see it as if we dont try to change this now we are gonna be stuck in a life of resistance ..having to jump though corporate loops to maintain which is nothin more then lack of self sufficiency..  disconnecting all middle and lower from being sovereign beings!
keep going seb! im interesting in hearing your results!!! be patient and double check your work. sometime being in a hurry we can over look somthings which can lead to no results while having the correct idea..
best regards,
outlawstc
