Author Topic: quick questions answered. electronics, building, math formulas, physics. anythin  (Read 12127 times)
I don't mean for this to be a blog, can I pulse a inductor straight from my function generator #10 copper insulated wire 150 turns around magneticish core 4ohms resistance. Can I just pulse the base of a transistor or do I need to make a simple isolation circuit? Does anyone have a schematic with values? Thanks, Rami.
It depends on the function generator and the power draw of the inductor.
But most likely you'll switch it through a MOSFET, the gate is connected to the function generator.
A help for the starter: http://www.electronics-tutorials.ws/transistor/tran_7.html
Thanks for the link, I am still out there somewhere. The solution I was hoping for was yea scavenge a transistor from your bendini motor and pulse the base tie the collector to the12v battery positive tie the emiter to the positive side of the inductor. The neg. Side of inductor back to neg. Side of battery. Whalla. Not as simple as I thought. I don't think its going to pull to many amps . I don't know though. I did think about using my variac with one diode to give me 30 Hertz at whatever voltage I choose. The variac has a fuse built in. This is on Sm. EPG. I am just ready to do it to see if concept works. God bless.  Rami.
OK. I just realized I'm having a conversation with myself. I've never caught myself before. Wow hope the kids don't find out.
I didnt do any test today. Odd thing happen I let it set overnight and lost pressure. No apparent leaks. Listened to all connections with hose (  redneck stethoscope ) no offensive. I just realized I have three cars in my front yard that don't run. I might be a red neck. Just checked a few minutes ago still holding at 15.5 psi the same pressure of nitrogen I started with. Makes me wonder if the hydrogen and oxygen recombined since it ain't moved in several hours. Ill check it in the morning.
After talking to an engineer he told me that the copper tubing will shield the magnetic field. So I tested copper vs. SS.  Using iron filing and test magnetic particles ( crushed magnet) the copper blocks part of the magnetic spectrum. The inductance from the inductor only affects the magnetic particles in copper. So the bottom line is use SS. Tubing. Didn't have aluminium tube to test. He just specified nonmagnetic pipe.
Hey if anyone can provide me with any help of any kind I would appreciate it. Look patient. Canada 1228833. And us. 4613779 .  Any in put to help move me forwards. Thanks RamiKatzs.
Hi Rami,
The recombination of H and O is not a proces that happens very quick if you have HHO gas in a bottle. So  you can eliminate that factor......
steve
Steve,  I know your right, without even looking at the pressure this morning. It was just kind of weird that for about 3 hours it equalize at15.5psi . The same pressure of the initial amount if nitrogen I added. Since there was no additional energy added to the system I wouldn't expect the recombination to occur at such a rate.  Yea I knew I had a minor leak. No problem, it will work for the tests I want to run. Has anyone else heard of or built an SM EPG?  I haven't seen anything on any threads. If Myers is not a liar or a fraud which I don't believe he is either. Then you all need to read the claims of the patent. In my opinion this is as great or better than hydroxy.  Sure seems more easily done as well. If you haven't read those patents you should. OK can anyone help me with the electronic side of things? Thanks RamiKatzs.
I had a discussion with Sebosfato on the EPG......
We both tried to get any magnetic reaction in the HHO but didnt get any any spike whatsoever on the scope with multiple sorts of coils.
Tried with AC and rectified DC on the coils.
Lots of HHO or little HHO.
Nothing.
If anything should work, then it might be water that is split by electrolysis. That seems to react on magnetic fields.
Steve, I would like to know more about the test specifics.  Have you had any conversations with dynodon? Please tell me all. Rami.
