Author Topic: Starting at the Genesis of Stanley Meyer's Work - The Demo Cell  (Read 43015 times)
Re: Starting at the Genesis of Stanley Meyer's Work - The Demo Cell
« Reply #56 on: February 20, 2011, 16:57:23 pm »
@Everyone:
Next week, I’ll have the .75” recessed groove in both end caps and I’ll post a picture of the cell with the o-rings in the bottom of the groove with the cell housing tube on top of it for the seal.
I used the cast nylon discs for end caps (as opposed to the Teflon discs I was originally going to use) due to the dramatic price difference between the cost of cast nylon and virgin Teflon.   Both materials are excellent electrical insulators so I made the more economical choice in selection.
@Steve:
Thanks Steve.  I’m having a lot of fun putting this cell together.
I am looking for a special material that I have been unable to locate.  I’m looking for the “quenching tube” that Meyer shows in one of his diagrams.  If you happen to know where I can purchase some, please point me in the right direction.  I realize that it may not exist on the market because Stan may have been the one who custom engineered it solely for his technology.  If it can not be found, I’ll use conventional hydrogen flashback arrestors instead.
Regards,
mina
« Reply #57 on: February 21, 2011, 07:10:58 am »
capillary tubing, you'd have to custom order, expensive, there are some more details (and link) in a topic in my projects section, forget which one though
« Reply #58 on: February 22, 2011, 07:07:12 am »
@Donaldwfc:
After searching through your projects section, I believe I located the link to the site that sells the “capillary tubing”.  The link was posted in one of your threads by Dynodon.
The following is the link:
http://www.paradigmoptics.com/structures/fiberstructures.html
I’m going to get some further material and pricing information from the company that Dynodon has provided.  Thanks again, Donaldwfc.  I looked all over for this stuff the other day and I didn’t even have the name right.  I was searching for “quenching tubes” when in reality they are “capillary tubing”.
Regards,
mina
« Last Edit: February 22, 2011, 10:13:26 am by Steve »
« Reply #59 on: February 22, 2011, 08:02:09 am »
@Everyone:
So far, this is my understanding of the Demo Cell construction thus far:
• The .75” tubes and .5” tubes are separated at the top with cross drilled holes filled with plastic doweling.
• The .75” tubes and .5” tubes are separated at the bottom with inverted figure “7” brackets only.  There are no spacers at the bottoms.
• The inverted figure “7” brackets are 304 stainless steel .75” wide, 0.030” thick.
• The negative hub is supported by SS stock (and not a tube) that is tapped on top and bottom and contains an o-ring on the bottom for a seal.
Now the only thing I was still wondering was what the size of the cross drilled holes at 90 degrees at the tops of the half inch tubes is?  Anyone care to speculate or provide this hole size?
« Reply #60 on: February 22, 2011, 10:16:38 am »
This would be nice, for the quenching tubes, however you must mind that the quenching tube work cause also he mix the combustible gases with non combustible gases prior to transporting it, this allow you to use bigger holes in the quenching tube while still avoiding spark to come back thru the tube...  The gas must be made safe as natural gas prior to transport it to the engine.
http://www.paradigmoptics.com/structures/fiberstructures.html#fiberlike
very nice steve
« Reply #61 on: February 22, 2011, 10:27:44 am »
Fabio,
The find is Mina's... :)
I just tried to get the link proper.
As you can see, all links can be copied now. But they dont show up as hyperlink anymore.
This solves the empty posts for now...
Still working on it....
« Reply #62 on: February 22, 2011, 12:48:37 pm »
Nice one, thanks man. And thanks mina nice link!
Br
Fabio
« Reply #63 on: February 22, 2011, 15:26:26 pm »
Mina,
the cross drilled holes were less than .125 inches.
sebosfato,
Stan didn't add non combustible gasses to the gasses coming from the resonant cavity.It was added in under the throttlebody.He said you would add non combustible gasses to it for transportation in pipe lines.
