Author Topic: Latest Success of a Vehicle Running 100% on Water  (Read 33772 times)
Re: Latest Success of a Vehicle Running 100% on Water
« Reply #72 on: October 27, 2010, 17:26:12 pm »
Mina, do you have results?
I may be able to help get results published/verified.
1) Can speak to Freddy.
2) Have spoken to Sterling Allan (PesNetwork, PesWiki).
Also would like to hear of your build details if you want to share.
You could email me at: komtek@cableone.net if you would like to exchange some input and ideas.
We can Skype too!
John
« Last Edit: October 27, 2010, 17:55:44 pm by komtek »
« Reply #73 on: October 27, 2010, 23:11:43 pm »
I think that Freddy used the negative and positive of his battery and his pwm to charge up the water and make it conducting. As soon as it conducts, the charge between the chair and his battery took over...
Dont you think that too?
Its like an electric discharge when you put yr hand on a metal door.....
« Reply #74 on: October 28, 2010, 05:09:57 am »
Steve, It was a small amout of time he turned on the PWM to 3amp.
If that succeeded to charge the chair negative and to run the cell for the rest of the video, does not compute very well in my thinking, but anything is possible it seems nowadays.
The cell stayed very vigorous when the current was removed, just as it had a 3amp or higher current still going to it.
I was told the chair was acting like a antenna so to speak, absorbing and using the energy from the environment. (that would be nice).
Also if it could have been used as a antenna, then how about trying this with a real antenna?
I can see it would be nice to make a test of the single pair of tuned tubes.
Does not appear very costly.
Mina I may have misunderstood you, I was told pretty soon a replication will be completed and shortly after that a PDF will be published.
We can only sit and wait for that to happen.
Wish they could spend more time on it but I'm assuming everyone has a real job and builds as spare time becomes available.
I mentioned and someone else did also, for Freddy to make a video showing the chair and all connections to the cell. It sort of leaves you skeptical when you don't get to see the whole picture.
« Reply #75 on: October 28, 2010, 10:36:26 am »
What other catalyst in the bucket can produce his result?
gasoline
« Reply #76 on: October 28, 2010, 19:09:44 pm »
connection to a chair: reminds me of the cold electricity experiments, such as from drStiffler/mrh2o2 on YT - led's brighten up when touching the wire.
« Reply #77 on: October 29, 2010, 00:16:37 am »
Here a test of FF
« Reply #78 on: October 29, 2010, 00:46:49 am »
wow
How does it work?
future energy concepts subscribed to my youtube channel...
I will try to contact them.
« Reply #79 on: November 03, 2010, 17:11:53 pm »
having had three associates visit from different parts of the USA in August, and having had conversations with Freddy and his partner, I would not get too excited about any of this. A lot of stories to tell...bizare happennings
Kind Regards
Mark
