Author Topic: The Master Plan  (Read 5901 times)
The Master Plan
« on: July 10, 2010, 19:38:49 pm »
hello all, i have been doing much thinking..  from what i can see from where i stand now is there isnt any reason to replicate stans circuits. at least the ones used to attain the patents.. i think we should interface the optocouplers that drive the output to the usb..  this will give us a way more versatile platform for a wide range experiments..
i think if we can figure out how to control the optos and also how to send a feedback into the usb then maybe one day we could apply a resonant scanning software...
also i would like to be able to apply the ancient tones in high power switching..
UT – 396 Hz – Liberating Guilt and Fear
    RE – 417 Hz – Undoing Situations and Facilitating Change
    MI – 528 Hz – Transformation and Miracles (DNA Repair)
    FA – 639 Hz – Connecting/Relationships
    SOL – 741 Hz – Awakening Intuition
    LA – 852 Hz – Returning to Spiritual Order
when stan says pulsed in sequential mode it makes me think of this.. lets say you are applying 8 volts and you had your frequency pulsed in a sequence such as this set above. lets say its a 50 percent duty for all frequencys.. the first one is 396 this frequency will have a longer on time and off time then all the others it is the lowest freq..  852 will have the shortest on and off time then all them.. both being repiticious they have a difference of 456 pulses.. the question is what are the characteristics of a coil current that is having such a sequence applied??
here is a cool site i found that has a bunch of usb circuits for sale..    http://www.j-works.com/index.php
Re: The Master Plan
« Reply #1 on: July 10, 2010, 20:58:36 pm »
Re: The Master Plan
« Reply #2 on: July 12, 2010, 05:53:53 am »
So VVTF are you waiting for ?
You take 6 cd4047 with tuned freq , you take a multiplexer , you take a mosfet driver , you take a MOSFETS . If your really smart you can do this with logic gates , that wouldnt be a shortcut however . An idea just popped in my head but I am too lazy to think it throught , this requires too much mental effort you see ...
I let you figure out the rest , nobody will figure this out for you trust me , read up ,  google up .
Forget the forums, you are invisible to them and will be treated like a incompetent monkey  unless you ask a very specific question .
« Last Edit: July 12, 2010, 06:09:17 am by Dankie »
Re: The Master Plan
« Reply #3 on: July 13, 2010, 02:26:29 am »
lol dankie and the 2 cents.. maybe im writing this for my self maybe these are some of my side notes...
24                                         Programmable Digital I/O Pins from your                                         USB Port
(http://www.hobbyengineering.com/pics/i3387-200x104.jpg)
http://www.elexol.com/IO_Modules/USB_IO_24.php
http://www.hobbyengineering.com/H3387.html
Re: The Master Plan
« Reply #4 on: July 13, 2010, 03:41:55 am »
So what u waitin for , do it ...
Re: The Master Plan
« Reply #5 on: July 13, 2010, 07:12:59 am »
keep reporting regardless of results outlaw... Think of it as the Edison Method "I learned 10,000 ways, how NOT to make a light bulb" you do 5 someone else does 5 etc etc till someone reads them all and comes up with the 10,001 method that we were all trying to do :)
As for Dankie... As displeasing as it is too see his "forum entertainer" badge gone it still rings true... I look forward to your results on the matter.
Re: The Master Plan
« Reply #6 on: July 13, 2010, 14:24:42 pm »
i agree ewok... im gonna look into this situation some  more and maybe get one of these to play with in the near future.
dankie, i think you have painted your potrait well this year.  dankie do you know what the number one demotivating thing is to ones progression? anothers negative visions.. well at least for most who dont understand power.. me i see you as kinda childish now... i see you wearing the jesters funny hat but you are not funny.. you where the hat because you feel like you are funny with your insights   you choose negative collaborations to resonante you aka impower.. you say things like you gonna have to do it on ur own cause no one is gonna help you... i dont beleive that one.. that is a normal situation for somone who is a A hole to others, which is not me..
"its a univeral melody possessing you and me universal magnetic never ending reaction proppelling actions reaching for satisfaton"
Re: The Master Plan
« Reply #7 on: July 13, 2010, 15:19:29 pm »
A digital or computer controlled oscillator or pll circuit is not going to make you find the OU frequency generators are so simple and even the pll that stan provided...
my proposed circuitry can be build with much easy the only thing it miss is a mean to control the output current but this can be done easily adding an inductor in series with the primary or resistance...
Just to remember
you will have resonance whenever you have a circuit where you can accumulate energy, (except batteries) springs, magnetic spring , pendulums, inductors (positive reactance _XL) + capacitors (negative reactance_ -XC)
