Author Topic: Dankie invents again  (Read 6542 times)
« on: June 25, 2010, 03:32:21 am »
So after building the best oscillators ever I have done it again ,. I have built a bunch of crazy oscillators  I actually invented a massive 3 channel harmonics phase shift pure oscillator that is 100% stable . Using the appropriate analog logic that I invented with a ramp wave and comparators I created this I can make a 0-5 Khz phase shift pure sine oscillator that has no jitter and phasing issues that I can adjust with a single pot phase or amplitude and a intuitive pwm I have done it again . Some other stuff I took from others / made better / fine tuned / selected best fastest components / rendered perfect .
But that is not my latest invention , I have built the proper ampilfier to test out my oscillators , this is effectively my 3rd invention , true non-existant circuit topologies . This was the result of much analysis on what exactly is goin on with an inductive circuit , as you know the coil tries to keep the current constant , this means that the control device has to absorb the reactive energy , this is not natural as true ac is , since the source of typical generator AC is itself a piece of wire coil and not a device proned to failure and seconda breakdown . This is the reason for the bias , maximum reliability , the use of  mosfets makes this indestructible .
This is my invention , this amplifier circuit does not exists in any book , nobody biases and uses the wave in this way for audio , yet it has a few advantages over class A push pull , it is litteraly my invention and nobody does this in this way . First advantage is that is far more efficient when we have an amplitude modulated signal as dc bias is never affected by amplitude variations , unlike class A push pull or single ended . It is also durable .
I have already begun steps to patent this topologie and have already payed for research @ the patent office .
The op amp that should be should be fast slew rate , not current feedback type , good rail voltage , stable at low gain  .
As you can see this works semi-ok with various capacitive loads /reactive loads / resonant loads .
This is still un-built physically , I am about to build it with a "proper" pcb . I dont suggest you actually attempt this very difficult build without me doing it first and telling you if it is worthy to spend that very limited effort that you can squeeze out of your body . And it this is better than using an alternator , there is in fact a difference , it is more difficult to drive a complex reactive load with an amplifier , I am not gonna embark onto why that is since most of you did not research this or understand the math .
I have pust here different famous circuits , one i class A like voltage follower , other is the classic single ended , maybe you wanna learn a bit .
I will come back and give news of this once I have fully perfected and adjusted the design .
Good day !
« Last Edit: August 22, 2010, 15:43:24 pm by Dankie »
Re: Dankie invents again
« Reply #1 on: June 25, 2010, 13:12:55 pm »
but why would anyone need a 3 phase oscillator?
« Reply #2 on: June 25, 2010, 13:36:02 pm »
this is a single phase amplifier , you could make it 3 phase if you have the right oscillator .
You are right , nobody needs a 3 phase oscillator
« Last Edit: June 25, 2010, 15:21:03 pm by Dankie »
« Reply #3 on: July 12, 2010, 04:25:46 am »
(http://www.ionizationx.com/file:///C:/DOCUME%7E1/Lawrence/LOCALS%7E1/Temp/moz-screenshot-3.png)Now here is what I said before but was censored by Tony Woodside .
As you can see my amplifier dont work for Stan , all these errors mean it dont work .
It works well when both sides see same impedance , Puharich or Stephen like .
It works like a charm for modulation like I said , I have the perfect little am circuit that works just fine also .
So I decided to finish my project after all since this hellish crazy project will be nice on my resume anyways , when I come back from work I do a little pcb , its goin slowly since this is boring but its 80% finished so ... The dual 3 phaser , the Puharich . I will not post the actual components and what should be done to make this functionnal , the circuit itself is only 50% of the working device anyways . Everything you see here is under patent application , alot of work went into this ladies and gentlemen .
I also made a kapanadze oscillator for my kapanadze experiments , it works real nice actually  , those circuits posted by the russian guy work  , modified it a bit , Im gonna draw it up and post it on energeticforums . Its basicly a simple 4 component add-on to my EEC P mosfet design , now isntt that great ? You see how things add up easily when the HHO God is on your side . I was gonna take out my Stan pulse to save space but it looks like it will have a use after all .
« Last Edit: July 12, 2010, 07:13:08 am by Dankie »
« Reply #4 on: July 16, 2010, 08:56:26 am »
I never censored you???
« Reply #5 on: July 26, 2010, 01:42:22 am »
So I am making much progress these last few days , its long because theres so many things I must take into account , star ground , recirculating current , short distance from the driving amp to the mosfet , magnetic coupling between power lines and signal and feedback lines most be carefully tought out and shielded , everything has to be tucked in between ground neatly . I am extremely happy with the lower part of the board , I managed to respect the rules from this app note I got here and made this cool and symetric looking and very space efficient  . I am now reworking the top a bit , wich looks noob and innefficient in space .
So this thing is 10.5 inches long , I am gonna brg it back to 9.5 inches long .
How this is gonna work is that thhere will be heatsinks on the side and an air cooled fan , 12 mosfets here believe it or not . The pre amp and driver stage is power by +-24 dual power supply , this will pull about 250 mA , and there will be a 12.6  volt car battery or ultra heavy duty power supply powering the mosfets . I am also using irf mosfet now instead , using some feedback and a simple biasing scheme . Its an design used by many with my very own twist .
I also discovered that my amp works great whern theres a diode in the circuit after all , the parameters were messed up on my sim . So yeah , just really progressed these last few days , theres no way this isnt getting released .
I also re-tought everything and reduced the cost of components to the point where all components will cost less than originally tought with lateral fets , wich is a massive accomplishement for something this big . This will be a thing that I will make for everybody @ cost + hour fee of fabrication and hourly cost . dollar an hour to assemble . I will keep these cheap , these will be cheap because I will copyright the board and the circuit . This will cost about 2500$ but will be worth it in the long run . Everything will be there to see and repair ( if it were actuaslly to be damaged in a themonuclear post apocalyptic future if it wasnt in a faraday cage )  just like any other cheriched piece of equipment . I recently learned that you can patent any circuit wich is totally different and tons of add ons were added , the 3 phase logic I use is infact the only thing thats wasnt my original invention . And if the board is yours that it is infact a product that is legally ptotected  .
This is effectively the worlds first high frequency linear 3 phase amplifier , its also a solid state am modulator transformer coupled for Puharich and other type of experimenting . And a pulser  ... The top side is the pulser logic and was made carelessly since it dont matter for cmos .
All is not finished as you can see , finishing up and examining .
« Last Edit: July 26, 2010, 03:32:13 am by Dankie »
« Reply #6 on: July 26, 2010, 03:06:20 am »
Yes I tought this was gonna be obvious , all you need to to is flick 2 switches or unsolder a resistance to take a single phase . All phase are controlled by a single pot knob .
There is another detached sine oscillator right there that is tuned for a slower freq and a mixer .
So w/e you ever wanna to do its possible .
BUT , all is made to work with center tap audio bandwidth transformer , made or sold seperatly . These I heard were superior to single ended , high power models should be made at home or copied from pro type transformers .
These use special cores , and tuning of materials etc , just like the VIC .... But 1:1.73 winding can be made manually in 30 minutes , wich is just cool for us .
« Last Edit: July 26, 2010, 03:23:16 am by Dankie »
« Reply #7 on: July 26, 2010, 05:40:05 am »
So what you guys think ?
Are you in awe by my nice criss-cross design ? power supply integrated right there .
The way I imagine this is like this , we use 2 wire of 10-4 three phase wire . Every channel of mosfets sees a  hot wire , both wire ground go to battery and center .
Batterie(s) right under the unit box fitting perfectly , transformer besides or over the whole thing. Ultra clean and neat. and taking up little space .
I can just dream about the awesomeness as I take a sip of this corona , mmmm .... Must go to work now .
