Author Topic: Bux green mower  (Read 6507 times)
Bux green mower
« on: June 02, 2010, 19:20:42 pm »
I got this mower about 2 years ago. It was broke down and I had to fix a bunch of stuff like all new blades, belts, tubes and the factory carb always gave me problems. I decided to try building a vapor carb after my old one got clogged or something. The bubbler works with gasoline but needs to have more adjustments to fine tune engine from cold to hot run modes.Also the fuel level within the bubbler runs best at a certain level. Too much or to little and it will either run lean or verysuper rich. I have never had any combustion occur within the bubbler.  After about 5 min of running the mower, the bubbler becomes cool to the touch. Like air conditioning. The bubbler is something of a project to "fine tune" as any other part. Here is a link to see the vapor carb on my mower:
After using the vapor carb I got an idea on the fuel demands and variances in them at cold and hot engine temps. But the bubbler alone does not do everything that a heat exchanger would do so I decided to go for it and make one like Paul Pantone's free online plans. I build the GEET reactor and am in the process of installing it on my mower. Here is a vid on the reactor build:
Re: Bux green mower
« Reply #1 on: June 03, 2010, 16:06:05 pm »
Those are very good video's, CN!
Loved that action vid on the grasmower...hahahaha
To give you a tip on your construction:
The innertube and outertubes are ok, but you could try to make one endbouching bold on the outside. (No threading)
Use a copper ring to make it airtide.
So, when you mount it all together with help of those endboucing, which you screw on the innertube, you tight it all up.
Re: Bux green mower
« Reply #2 on: June 04, 2010, 00:48:53 am »
I'm glad u like the lawn mower cruse at full speed! Good advice there Steve. I also recommend doing it that way now that I have more experience. Hopefully mine dont leak.
Anyway, I made another vid on my build. I call this one the installation.
I started by cutting the front of the frame off for more room. Then I cut the muffler can off.  Next I welded the intake fittings on the bubbler and intake manifold. Also put all the firrings on the reactor. I still have the factory carb on the engine. Ill make my first tests with it in place.
(http://i75.photobucket.com/albums/i283/carbednotch/mower.jpg)
I wonder what fuel I should try first?
Re: Bux green mower
« Reply #3 on: June 04, 2010, 01:46:38 am »
(http://i75.photobucket.com/albums/i283/carbednotch/mower2.jpg)
Got a bran new hi-flow muffler can! Sweet!!!
Re: Bux green mower
« Reply #4 on: June 04, 2010, 09:11:42 am »
my suggestion is to start with petrol and water on a 50% basis. That will work well.
steve
Re: Bux green mower
« Reply #5 on: June 07, 2010, 00:14:51 am »
I got a bunch done to the mower this afternoon while getting rained on.
Here is a second part to the first set of vids.
Here is a picture of how she looks right now. Her battery was dead so its getting charged as we speak. I decided to use 4 cups of 87 gasoline to start with and see. I'll start adding water after.
(http://i75.photobucket.com/albums/i283/carbednotch/carbednotchvhrmower.jpg)
Re: Bux green mower
« Reply #6 on: June 07, 2010, 03:03:21 am »
 ;D   Mower runs really good!!!
I can only run a 5050 mix gas water or else steam builds up.
It runs like a champ on the 5050 mix.
Regulating the bubbler level still remains an issue though I can say that the bubbler works much better than before.
« Last Edit: June 08, 2010, 03:26:20 am by CarbedNotch »
Re: Bux green mower
« Reply #7 on: June 07, 2010, 03:49:21 am »
check out my page for my latest videos.
I found out the best mixture is Dr. Pepper and gasoline.
« Last Edit: June 08, 2010, 03:27:01 am by CarbedNotch »
