Author Topic: Electrolysis using tungsten rods and KOH  (Read 4226 times)
  • Yes I got Jolted,
« on: April 18, 2010, 23:25:23 pm »
I just tested performing electrolysis using 2 tungsten rods and koh mix.
reaction starts at about 1.2 volts
only the negative rod shows gas,
nothing at all on the positive rod, even when I raise the voltage to 8 volts.
why no gas (oxygen) on the positive rod?
Re: Electrolysis using tungsten rods and KOH
« Reply #1 on: April 18, 2010, 23:29:58 pm »
Probably a chemical reaction which will form a coating , just like with the aluminium tube we tried last year?
  • Yes I got Jolted,
« Reply #2 on: April 18, 2010, 23:32:33 pm »
I'm glad you mentioned that.. maybe this water i'm using was some leftover from last year's tests and is contaminated with ALU.
will test again with a clean mix.
  • Yes I got Jolted,
« Reply #3 on: April 19, 2010, 18:09:54 pm »
yes there was some aluminum dissolved in the solution. that is why only hydrogen was being generated.
