Author Topic: Making the Magic Gas to run an ICE  (Read 9167 times)
Re: Making the Magic Gas to run an ICE
« Reply #24 on: May 11, 2010, 16:53:38 pm »
Thanks for the DOC Steve.
Back to the Nitrogen patent.
The chamber or vessel to hold the arc, can we make this from polycarbonate or other plastics?
I guess after prolonged use plastics would deform a little, if the arcing is near.
Electrojolt, can you elaborate how you make the oxygen removal part.
Its a very good idea, to maintain higher N2 output.
I may have missed something.
  • Yes I got Jolted,
« Reply #25 on: May 14, 2010, 02:09:45 am »
right now i only have a theory, not sure if it
will work. basically try to charge oxygen with hv. then use same hv but opposite voltage to attract the charged oxygen away from nitrogen. now im assuming that oxygen is easier to charge than nitrogen.
