No chemicals!
Last test spring water but doesn't matter tap water is the same, plenty of foam.
Will try rain water but I'm expecting the same result.
Looking at all others tests its the same stuff nice white foam bubbles filling the cell water bath.
Most of these tests appear to be straight no chemical water, spring tap or rain.
Look at Kevin West same stuff. For several years of water-cell video's its the same stuff. Meyer video's, Ravi's, Lawtons all of them.
Plenty of white foam.
I'm interested in converting the foam but no added chemicals.
Maybe filtering and processing, maybe another voltage zone.
But no chemicals, or how would an anti foaming agent work?
Has to be a way to keep it simple don't you think?
The foam has the appearance that it is split but the waters surface tension won't let is all release.
Some gas comes out but not all.
