Hello steve , its a 1.5 Kw which is 2 HP (1500 Watts) single phase motor so its quite a bit . I read in the paperwork that its about 8 amps @ full load .
John
Yeah thats the issue with this , it was designed to be a fuel saver add on thats ran with your petrol enginer , maybe you could switch halfway after getting it running right if you had all the gas processor tech to go along , never will it be overall OU even if it was resonating and producing extra gas .
You could use that much power and a cooling system and produce 15 LPM with some parralel car batteries plain electrolysis .
In the industry we never use single phase , its a complicated and costly device to maintain and has less torque and speed for the same amount of energy than 3 phase . I would suggest to find a 3 phase motor with some big gears and a make yourself a 120 volt high amp DC powersupply or some batteries and buy a 3 phase speed control driver pwm . You will save about half the wattage this way and you will get higher torque and speed and be able to reach higher frequencies , you cant experiment properly without a speed control driver , that thing is a must . These are common in the industry and usually cost about 150$ for a nice driver .
I am currently looking into this , I believe can switch my oscillator into a 3 phase pwm driver with 9 extra components and a pcb for all those and mosfet drivers not ring too much .
