Here is something that will time everything perfectly .
No overlap , a few nano seconds before the HV stops , the static pull begins .
Give it a try . For mosfet driver theres alot out there , very simple to operate if you consult any datasheet , all the instructions are there for even complete noobs to operate . But you must keep leads very short and wide . No more than an inch between mosfet driver and mosfet and large wire , I use very wide planes for mosfet on my pcb .
This circuit is on my pcb , you can have auto-gating with either divide by 2,3,4,5,6,7,8,9,10 on a rotary switch or divide all those by either 2 or 4 once more .
So a maximum of divide by 40 spacing . For asymetrical gate/pulse ratios you must use manual jolt gating.
Yes I am the #1 LOL .
Low-side mosfet = N Channel mosfet
High-side mosfet = P Channel mosfet
All of these logic gates are different gates , no exeption , only their numbers are the same because I copy pasted , dont let that confuse you . Wired as is
