Author Topic: Open letter to P. Lindemann  (Read 28677 times)
Re: Open letter to P. Lindemann
« Reply #48 on: October 23, 2011, 03:40:19 am »
Stan did not use UV light. The reason why he did not use UV light is because it would exceed the work function of the SS and create a photoelectric current inside the Hydrogen Gas Gun. UV light would pluck electrons off of the plates and send them into the gas cavity, which is exactly counter to amp restriction process that is required to ionize the combustible gas atoms.
« Reply #49 on: October 23, 2011, 03:42:38 am »
Nitrous Oxide is discussed in the Exhaust Reclaimer Technology in the Tech Breif, it can be broken down and completely eliminated. It is not desired, and yet even without eliminating it, it is minimal as a byproduct anyway. Listen to him talk about it in his various lectures.
« Reply #50 on: October 23, 2011, 08:30:22 am »
That isn't UV???
« Reply #51 on: October 23, 2011, 08:41:28 am »
Sorry but you forget if you think that only hydrogen produced from WFC run an engine 100%.  Nitrous oxide is formed from oxygen of water during the process and is, with ammonia, the other main component for reach right green fuel. Document attached is extracted from scientific analisys.
« Reply #52 on: October 23, 2011, 08:44:05 am »
Everything I said was correct. You have some more learning to do.
Sorry .. in part is correct.. however explain chemically with formula what is your water fuel. If you know for you is simple write that.. My formula is 8N2+6HHO+Hv=4NH3+6N2O.. yours??
« Reply #53 on: October 24, 2011, 00:53:49 am »
That isn't UV???
If you list all of Stan's technologies, UV light is not required for any of them. That is talking about recycling water AFTER it's been used. This is not required, it's just another approach instead of letting the water go out the exhaust pipe and then into the atmosphere, and through the cloud/rain cycle. If you use UV light anywhere else in the process you will screw it up by creating a photoelectric current.
« Reply #54 on: October 24, 2011, 00:56:42 am »
That doc is not related to Stan's work, you are confusing different systems. Read the exhaust gas reclaimer technology in the Tech Brief, it will tell you how to completely eliminate Nitrous Oxide.
« Reply #55 on: October 24, 2011, 00:58:27 am »
It's not a chemical process, it's a physical process. I see you are not working on Stan's tech at all, you are doing something else. I wish you luck with that. I hope my comments here serve as a record to other researchers that they may distinguish between Stan's work and the other theories out there. I correct your statements in reference to Stan's technology only.
