Author Topic: How to choose and work with toroids and capacitors  (Read 2149 times)
« on: December 22, 2009, 12:16:19 pm »
Hi all,
Here is a nice doc on toroids.
« Last Edit: December 23, 2009, 11:19:40 am by Steve »
Re: How to choose and work with HV capacitors
« Reply #1 on: December 23, 2009, 11:18:49 am »
HV capacitors
You can buy HV caps, but they are extremely expensive.
You can choose to set some lv in serie.
Here is the formula:
Totall capacitance = (C1xC2)/(c1+c2)
2200 uF 25Volt + 2200 uF 25 Volt
Makes: 1100 MFD  50 V
Re: How to choose and work with toroids and capacitors
« Reply #2 on: December 23, 2009, 11:40:47 am »
if you use the same caps you can just divide the capacity of one cap by the number of caps in series.
example: 4 caps with a capacity of C1 in series, then the total capacity is C = C1/4
