Author Topic: Working resonance circuit  (Read 32477 times)
Re: Working resonance circuit
« Reply #64 on: December 21, 2009, 21:39:26 pm »
I tried to do a simulation to create opposite voltages of equal size, works as a charge-pump.
Used a center-tapped transformer.
Maybe I got it mega wrong! ::)
code:
$ 1 5.0E-6 0.41233529972698213 42 5.0 50
g 736 368 800 368 0
l 464 256 560 256 0 0.2 0.46392002014487865
d 592 256 656 256 1 0.805904783
169 400 336 464 336 0 0.2 1.0 0.45006014272370953 -0.4639200201448792
c 592 256 736 368 0 2.8E-7 1403.6467632373617
d 656 480 592 480 1 0.805904783
w 464 368 736 368 0
r 736 368 736 256 0 1000000.0
r 736 368 736 480 0 1000000.0
w 736 480 656 480 0
w 736 256 656 256 1
g 352 448 352 480 0
w 528 480 592 480 0
w 464 336 464 256 0
w 464 400 464 480 0
c 736 368 592 480 0 2.8E-7 1402.6533236931011
l 528 480 464 480 0 0.2 0.4567661576538239
R 272 336 208 336 0 1 672.552 12.0 0.0 0.0 0.5
w 352 448 352 400 1
d 352 400 352 336 1 0.805904783
w 560 256 592 256 0
w 272 336 352 336 0
w 352 400 400 400 0
w 400 336 352 336 0
o 8 64 0 35 2239.7447421778043 0.002734063405978765 0 -1
o 7 64 0 295 2239.7447421778043 0.002734063405978765 0 -1
br,
webmug
« Reply #65 on: December 21, 2009, 21:42:25 pm »
Is simpler than that,  a coil and a  a capacitor, and a transformer for 10khz few turns on the primary and 3 times more on the secondary with 3,5mm wire. Connect everything, secondary, choke, capacitor, cells and than close again in the secondary what you get is a parallel resonance, use a capacitor between primary leads and a capacitor from source to drain of our mosfet, Use a diode in series from positive side of the batery to the primary... Resonance simply . connect an Ameter in series with the circuit and on the primary. and a voltmeter and frequency meter between the choke sides.
Hi Sebos,
You use 3,5mm wire? Man, thats very thick!
Thanks for the advise.. :)
« Reply #66 on: December 21, 2009, 21:50:58 pm »
Have you seeing this?
Some say that this is hygienic paper and that Stan found the solution when he was at his bathroom, what he had is his bath room that lead him to discover it? think about don't ask me
I believed this drawing was made at a cafe by Mr Meyer and given to a journalist or a friend.I clearly remember i found it on a web page with that kind of explanation, and posted it here a year ago :
http://www.ionizationx.com/index.php/topic,665.msg7182.html#msg7182
Kind regards
Yes, and at that time i had a discussion with some people on what all components could mean.
I just forgot about it, because that capacitor was confusing..
Now, the world is different....
« Reply #67 on: December 21, 2009, 21:57:15 pm »
code:
g 736 368 800 368 0
w 464 368 736 368 0
w 736 480 656 480 0
w 736 256 656 256 1
g 352 448 352 480 0
w 528 480 592 480 0
w 464 336 464 256 0
w 464 400 464 480 0
w 352 448 352 400 1
w 560 256 592 256 0
w 272 336 352 336 0
w 352 400 400 400 0
w 400 336 352 336 0
br,
webmug
Nice setup, Webmug.
You use 1mega ohm resistors as wfc.
I think that a little bit high... ;)
In my tests with tubes, i found resistance between 0.5 till 10 ohms..
« Reply #68 on: December 21, 2009, 21:57:53 pm »
the thicker the better, as you have higher Q. Didn't your coils heated up? My ones burns while the vic works cold. The series configuration heat up a lot the input transformer that here is a iron powder one.
Actually i used up to 5 mm the coils become very heavy and big than doing that i discovered something i'm going to tell you now
Stans choke was so big and so in front of us all this time look at the buggy. In the video
was that big thing behind him when he talks that it can works with snow. Is at least a 200mh air coil under vacuum.
I know because i went to a transformer fabric and when i proposed 40kv 5 amps he said you will need to go to vacuum. And showed me something just like that.
On the other meyer video
you see it in another way connected straight to the cell Is on the right side of the car something Round and big.
« Reply #69 on: December 21, 2009, 22:06:37 pm »
seb are you talking about the blue electric motor looking device?
« Reply #70 on: December 21, 2009, 22:10:25 pm »
code:
g 736 368 800 368 0
w 464 368 736 368 0
w 736 480 656 480 0
w 736 256 656 256 1
g 352 448 352 480 0
w 528 480 592 480 0
w 464 336 464 256 0
w 464 400 464 480 0
w 352 448 352 400 1
w 560 256 592 256 0
w 272 336 352 336 0
w 352 400 400 400 0
w 400 336 352 336 0
br,
webmug
Nice setup, Webmug.
Strange circuit :o, where is the potential coming from if you have max. 10 ohms cell, from inductor and choke???
My plate cell has 0 ohm but when its charging it rises to 7k ohm or more. My 6 parallel tubes cell has 1M ohms 1,5mm gaps? :-\
br,
Webmug
« Reply #71 on: December 21, 2009, 22:12:11 pm »
not the motor what suppose to be the cell in the first video
In the other is different if you look at it
