Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 37974 times)
Hi Tut,
Thanks for posting here again.
You are saying that the trick is to use hho in combination with ambient air, mix it and then put them thru uv light?
How much led power would we need?
1, 100watts?
As in chemical formula use only nitrogen and you obtain stechiometric mixture in the time..
Nitrogen extracted from air trough membrane..
Brown gas mixed with nitrogen and sended inside UV reactor.. Yes.. after you obtain new fuel that I have called micronic formed from ammonia and nitrous oxide.
With formula you can simply calculate right amount of nitrogen mole mixed with water gas mole for obtain new fuel formation
About UV...Low wattage.. 10W max are ok..  UV beam is only important, better use lens or little gap from UV irradiation.. no more heat you need during the process
With UV reactor you can create in real time micronic gas and sent inside engine directly without special injector.
« Last Edit: October 08, 2011, 12:28:33 pm by tutanka »
About Patrick alias Iontruster alias Oneminde
Inside eureka pdf document is written:So I proposed this new chemical formation to Tutanka (Alessandro) and be hold. He back stabbed me and took all the credit, releasing this material in Energeticforum.com under his alias.
These statements are completely false! Him contact me for obtain informations for build and sell reactor but when I have understand that I have immediately cut any contact with him trough skype and also I have written that on energeticforum.com.
Project of Patrick or Oneminde was build an voltrolisys cell for creation of brown gas based on Meyer documents but surely don't have reached the success because this type of person don't create anything just copy .
However I am really disgusted by this kind of people who unfortunately are on the internet and stealing the work of others.
Attached photos are of my system mounted for powered an cogenerator of 500kW.
Mr. Patrick (alias Oneminde on energeticforum.com) please sent also you photos of yours system, you don't have written that are you the creator of micronic gas??
Unfortunately for oneminde all remain written on forums, I have just spent two minutes for found these:
http://www.energeticforum.com/renewable-energy/5381-ammonia-nh3-fuel-car-3.html#post86852
http://www.energeticforum.com/renewable-energy/5381-ammonia-nh3-fuel-car-3.html#post86877
http://www.energeticforum.com/renewable-energy/5381-ammonia-nh3-fuel-car-3.html#post86889
http://www.energeticforum.com/renewable-energy/5381-ammonia-nh3-fuel-car-3.html#post86896
« Last Edit: October 08, 2011, 14:51:20 pm by tutanka »
Hi Tut,
Did you run that hugh engine on HHO and micronic fuell alone?
No diesel or petrol, or whatever?
Micronic gas can run an engine completely, cogenerator 500kw is based on 20.000cc diesel engine and need every oil for start combustion. For legislative italian laws at this time cogenerators can use only 30% of green fuels as additive the other 70% must be oil or diesel. Attached extract from scientific document on NH3-N2O interaction.
OTHER METHOD FOR GENERATION OF BROWN GAS
At today you can found only faraday electrolyzers on market but as you know problem is high amount of energy needed for obtain properly reaction. At this time no more solutions are presents on internet, also Bob Boyce an guru on brown gas production don't have found another way and for low amount of gas produced use an large amount of energy and every the electrolyte inside water including some heat produced. At today I know that one or maybe two companies in the world are working on development on meyer cell. Initially working in tandem with Mike Nunnerley I'm starting project of reactor for creation of ammonia/nitrous oxide, we obtain these molecules in output but that system is composed from many stages. I had long planned to use the brown gas, the feeling that I was eliminated by simplifying the way the various stages of production of new fuel.   The brown gas has always fascinated me, and I have performed many experiments cannot deny that I broke two cells during the experiments. In any case I never had time to do experiments at the university to see what was actually Brown's gas. But today I can tell you with absolute certainty that the brown gas is only "charged water",  to change state from liquid to gas. With the brown gas I solve two problems, the proper mix of water with nitrogen and the other can eliminate the catalyst that emits electrons. The major problem still remained the production of gas. So I got to thinking, in my mind hundreds of readings of Meyer and Puharich and to the concepts of my reactor, all mixed together when all of a sudden I had the right inspiration. Puharich uses water and salt for the simple reason that the only water is "transparent" to radio waves. The water when it is "filtered sometimes"  is a very good dielectric. however the dielectric can be "doped". The dielectric can be used as an good emitter of free electrons, free electrons can be used to create an effect called "electron avalanche", but consider that water is also our source of hydrogen and oxygen then using this method the water dissociates itself. Two images are attached, first is extracted from patent 5,149,407 of Stan Meyer, second new cell in working state. The method I use does not differ much from Meyer the only difference that I used a completely different low voltage power supply and connected differently to the points A/B. I always thought that Stanley Meyer was a genuine genius, perhaps a bit too complicated, probably each of us has a vision and sometimes we think too "complicated" and the best thing is to think simply. Thank you for your attention. Regards Alessandro
P.S.
With the informations I have provided above an open mind will be able to build my same cell
« Last Edit: October 10, 2011, 16:46:42 pm by tutanka »
 THAT IS A NEW GAME FOR ALL PEOPLES
 FOUND WHAT IS THE RIGHT MEYER CIRCUIT AND YOU WIN THE TRUTH!!
 First circuit is extracted from Patent 5,149,407
 Second circuit extracted from Meyer Full Data document
Why the circuit cell connection on patent is different from the other?? What is the true and false?
« Last Edit: October 10, 2011, 23:07:41 pm by tutanka »
Alessandro,
The circuits look the same, except for the fact that they connect the electrodes on a different manner.
Electrons flow from negative to positive.
If the goal is to extract free electrons from water, then my first guess will be the drawing with the positive connection hooked up to the outer tube.
Is this the anser?
