Author Topic: Start here your topics on the water injector & ambient airgasprocessor system  (Read 43182 times)
I don't know anything about that unit.Couldn't tell which wires went where.Can't help out any.
I don't think that it was ever used.
if it wasn't used then might it have been a second one? and the original is away with the stacked cavity unit?
My guess would be it was the only one,but then the one in Meyers slides shows a sticker on it,and maybe a different one.The one I saw didn't look like it ever had a sticker on it,could still have been the same one though.
Can you offer any description of the control labels, switches, buttons and stuff that are on this controller for the stacked cavity assembly?
(http://img.photobucket.com/albums/v81/bigbuba/Frequencygenerator.jpg)
(http://img.photobucket.com/albums/v81/bigbuba/fractionation_controller.jpg)
These are the only two pictures I have on the control box...
I don't think that you understand the usage of the air gas processor.It does not process all of the air going into the engine.It only does a small amount.This processed air is injected under the throttlebody along with exhaust gas recirculation.Also the idle control air is added in there as well to control the engines idle spped.So you have ionized air,exhaust gasses and metered air,all going in under the throttlebody,in the vacuum area.
The air gas processor.tubes are the same size as the resonant cell.3 inches long.To ionize the air several thousand volts will be needed.
I remember in one video he says  11 percent.
in the Hydrogen Gas gun, do you know where the primary is? we see two coils at the bottom and one at the top. Any guess on the wire gage?
The coils at the bottom and the top were there to create a magnetic field that would increase the speed of the ejected electrons through the cavity and get them more quickly to the extraction grid at the output to make sure the electrons were extracted before they fell back to their ground state in the atomic orbits
the patent and video speaks of electromagnetic waves,  those are the coils that provide electron acceleration once the electrons are free from n=infinity in the ionization energy scheme.
Hey lads interesting thread.
Does anyone know if Stan had success in running an engine using the water injector?
For practical purposes of actually making an injector/ plug what would be a suggested drawing to work from?
Many people many opinions.
I personnally think he did ran with water injectors.
He had put in soo much effort. Made many proto's.
People close to Stan confirmed this.
Others standing further from him, deny.
Another thing: Stan presented that injector on seminars. You just do not such things if you havent anything working, in my opinion. So many people......and then presenting a hoax? I dont think so....
