Author Topic: real quick question  (Read 2691 times)
real quick question
« on: November 16, 2009, 19:28:04 pm »
hello there,
to all you guys with cells out there, how much amps straight-dc does a cell draw when immersed in clean tapwater?
please put your past results in here along with the volts. thanks.  :)
Re: real quick question
« Reply #1 on: November 16, 2009, 21:47:11 pm »
Here are some results of my tubecell:
http://www.ionizationx.com/index.php/topic,85.30.html
« Reply #2 on: November 16, 2009, 22:43:55 pm »
thanks.
Test 1 (with straight DC)
Volt : 12
Amps : 18
that's a resistance of 2/3 Ohms for the watercap. not good, even 2.5Amps with distilled water is <5Ohms.
when i had my tubecell it measured in the megaohm range even with water. need that for a good Q value.
it seems i have to try it out :(
« Reply #3 on: November 17, 2009, 00:35:09 am »
I had here many tests and from many different setups
I had tap water at 220 volts dc starting at 10 amps and than when it boil (1 minute) it than goes down to 2 or 2,5 amps. Using tap water and distilled water however distilled made much more hydrogen before boil and took about 1 minute more. The two plates were 20x10 about 1 cm far away from each other. Changing the distance didn't change much. The container had 4 liters of water and consumed about 1 liter every 15 minutes.
At low voltage about 1,4 volts and using sodium hydroxide i got up to 20 amps with my resonant scheme and water didn't heat up not even a little. However the wire heated up a lot and also the resonant capacitors. Voltage was about 300v with that conditions starting from 12v battery.
