Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 156831 times)
« Reply #96 on: October 02, 2011, 21:39:24 pm »
Can anyone help me please? I tried putting sumthing together to duplicate the EEC effect but I believe it exceeds my capability. I'm excellent with science but not so good with construction and machining item needed to work properly. I'm going to goive it another try on my own and probably won't stop trying. But in the end I'll need somebodies help to make this something that can be used everyday. Any and all assistance is appreciated.
Thank you FI3
« Reply #97 on: October 02, 2011, 22:13:38 pm »
Thank you FI3
Hi FI3,
We have the best electronic circuit here for you.
Its design was done by Electrojolt and you can find the whole description here: http://www.ionizationx.com/index.php/topic,1054.0.html
Regards
« Reply #98 on: October 02, 2011, 22:28:45 pm »
Hi Steve,
It's not the circuit I'm needing although electros circuit looks pretty sweet. I'm in need of help really with something comparable to the resonant gas processor unit.
« Reply #99 on: October 03, 2011, 00:39:03 am »
Fastimports,
Try putting your doubts here more clearly (exactly), lets see if someone can help you...
sebs
« Reply #100 on: October 03, 2011, 00:57:10 am »
brb gonna take a video but no laughing at my try i know I'm not very good at this designing from scratch and no money. The 1st plasma ignition I know of on youtube came from a trash can. I'm on disability supposedly for being crazy they tell me. I just think they're clueless and blind. I'll show and try to explain over the engine noise my voice is very low tone.
« Reply #101 on: October 03, 2011, 01:27:43 am »
ok here ya go the worse yet.
http://www.youtube.com/watch?v=Txqw1BFbHPY
when working properly it should have a HV source to start the process and a neon bulb with cap and scr or a spark gap to burn of electrons.
« Reply #102 on: October 03, 2011, 02:11:51 am »
My best guess is that you are having problems with the insulation... try using acrylic, thick...
Measuring with the multimeter can lead to problems... normally multimeters impedance is max 4Mohms
You should read DC on the Kelvin water dropper.
A scientific methodology would help you. Take measurements, plot graphics with the results to understand better what you are doing. This way you will be able to make improwemets and also explain better what you exactly need. Its really important.
if you could measure the air speed would be good parameter... but you can relate the rpm to the specific cross-sectional area of the tubing and the tension measured..  to find a relation useable... needed for design parameter.
« Reply #103 on: October 03, 2011, 06:04:19 am »
I wish I had a means of using wonderful technologically advanced scientific tools to chart exact data and prove exactly what it is I'm doing or disprove me. Or to take accurate measurements to aid in design of the next part. There's no such thing as a bad experiment or failed. If it goes wrong I failed but still learned, so not all was lost.
But I don't, I work out of a trash can for the most part $674 a month doesn't get you much. It would be nice to figure this out and not get rich instead teach all in hopes of making a living. There will be more then enough money for all to share unless your JP Morgan reincarnated. I just want to feel like I contributed something and that not all Americans are fat and lazy as I've seen written about us in plenty of places online. I'll give all I have away in hopes that I'm not left behind to live in poverty while others thrive on what I shared with them. I don't know how Stan did this on his own. It is extremely complex and expensive materials were used so I know it wasn't cheap. I've been to his house in Groveport he was not a rich man by far. But he was extremely paranoid. He converted downstairs into garage and had 6 500watt halogens on all 4 sides of that house with a orange flashing light on chimney. Back on topic here. I just got kicked out of hardware store again because they were closing. I love how they always ask are you looking for something I suppose I do appear crazy here. Because I never know what exactly I'm needing. But here are sum pics of what I got.
