Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 147010 times)
« Reply #56 on: October 15, 2010, 08:17:54 am »
Hey fst if that is the case your using too much fuel in normal driving conditions.
« Reply #57 on: October 16, 2010, 00:29:26 am »
That was my thoughts too Ewok I haven't had a chance to buy the adj fuel presure reg yet for a chevy tbi but it is on my list of things to try. Right now though the ionization of the intake air seems to be doing the job though. So it makes me wonder if it was too rich or if the water was too much and cooling the combustion temp too much.
« Reply #58 on: December 01, 2010, 01:25:57 am »
This is a neon power supply used in video...
I'm working on Tesla coil circuit to power a much larger cell.....
Here's a couple of links that will help everyone to build a working WFC.
Tesla Coil Cad
http://www.richardsplace.net/tesladownload.htm
This will allow you to plug your WFC capacitance in spot of top load or toroid to aid in building resonant transformers.
This is Andrija PUHARICH Water Decomposition by AC Electrolysis Circuit...
(http://www.rexresearch.com/puharich/2fig1.jpg)
And waveform
(http://www.rexresearch.com/puharich/1fig5.jpg)
Here's a link to the pulsing power supply needed to pull this off....
Eastern Voltage Research
Go here for Plasmasonic Instruction Manual (PDF)
http://www.easternvoltageresearch.com/datasheets/plasma2_manual.pdf
Features:
- Full-Bridge switching circuit for high power operation
- Configurable as pulsed SSTC or CW SSTC (Audio Modulation)
- Customizable Audio Filtering
- 10-Step LED Onboard VU Meter
- Connects directly to practically any audio source
- Operates from 50kHz to 350kHz
« Reply #59 on: December 01, 2010, 09:51:43 am »
A small comment from my part here.
Many people say that the puharich circuit is AC.
But is it?
Look how one side of the output circuit is hooked up to GROUND.
So, only half AC cycle possible there, is it.....= dc pulse
« Reply #60 on: December 01, 2010, 11:53:37 am »
Puharih Circuit is AC because he's using audio amplifiers to drive AC...
I full on believe it is a Tesla magnifier circuit aka voltage intensifier circuit.
Check out the wave form in the manual of the solid state tesla coil...
It is half wave rectified.
« Reply #61 on: December 04, 2010, 18:42:38 pm »
Why not use then a multiple of 2 tube sets for each half wave rectification.  That's what I played with in my ac experiments.  Each tube set gets a dc pulse with a 50% pulse width or rest period.
Regards,
Andy
 using emissions as patone device  I'm thinking about trying to use the engines air injectors from smog pump to create a pantone type device using the crankcase ventilation. Has anyone tried this yet?
 (http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/08/1f/ee//small/0900c15280081fee.jpg)
You mean that you want to use the carbon vapour?
