Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 126443 times)
0 Members and 344 Guests are viewing this topic.
Looks like a good photon adder to the mix .
I am really switching gears now as I see that Kapadze is almost at an armgrab , I need to clear away the disinfo end understand what sr was doin , I got itnow I think .
I am sorry if I cannot help you more than I have ..
The electrode where the bright light is seen from is where the free electrons are being consumed....
is that an EEC?
Electron Extraction Circuit???? =   EEC???
yes, is that what you are doing
Yes it is a EEC then by Stans definitions. It produces free electrons and consumes them as well.
WFC Experiment Reverse Polarity HV for Voltage Potential \ EMF
This   time we changed the polarity of the diodes and ended up losing the   bright yellow light on the sparking electrode. I believe the H2 is now   being produced on the cell vs consumed in the spark.
« Reply #55 on: October 15, 2010, 08:04:50 am »
I used a 7kv neon sign transformer then full wave rectified it to make a particle charger out of it. Then put the pos side to intake of fogger unit and neg side to the output to engine intake of the fogger unit... Noticed improvements here in acceleration. Have not tested mileage only
 Before adding particle charger no gas mileage was gained when not towing and engine would load up or respond sluggish. But did notice torque improvement during heavy tow applications was noticed allowing vehicle to hit higher speeds when used under load with improved gas mileage when towing.
