Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 147503 times)
0 Members and 20 Guests are viewing this topic.
« Reply #24 on: November 30, 2009, 13:33:20 pm »
I think this unit will work $200 10 Disk Ultrasonic Humidifier
3000mL of water to fog a hour
« Reply #25 on: December 21, 2009, 16:26:14 pm »
Catalyst Demo using N2O Nitrous Oxide NOS
Blowing N2O Nitrous Oxide through a Dajrum Black Clove. COMPARE FLAMES TO RELATED VIDS LISTED The general feature of catalysis is that the catalytic reaction has a lower rate-limiting free energy change to the transition state than the corresponding uncatalyzed reaction, resulting in a larger reaction rate at the same temperature. However, the mechanistic origin of catalysis is complex. Catalysts may affect the reaction environment favorably, e.g. acid catalysts for reactions of carbonyl compounds form specific intermediates that are not produced naturally, such as osmate esters in osmium tetroxide-catalyzed dihydroxylation of alkenes, or cause lysis of reagents to reactive forms, such as atomic hydrogen in catalytic hydrogenation. Kinetically, catalytic reactions behave like typical chemical reactions, i.e. the reaction rate depends on the frequency of contact of the reactants in the rate-determining step. Usually, the catalyst participates in this slow step, and rates are limited by amount of catalyst.
Hot Steam Cold Fog Flame Test.wmv
The ionized atoms along with free floating negative charged electrons are, now, deflected (pulsing electrical voltage fields of opposite polarity) through the Electrical Polarization Process ...imparting or superimposing a second physical-force (particle-impact) unto the electrically charged water bath. Oscillation (back and forth movement) of electrically charged particles by way of voltage deflection is hereinafter called "Resonant Action", as illustrated in Figure (1-10). Attenuating and adjusting the "pulse-voltage-amplitude" with respect to the "pulse voltage frequency", now, produces hydrogen gas on demand while restricting amp flow.
Stanley A. Meyer
 A little bit about Ultrasonics now...
 Ultrasonic power supply (generator) converts DC voltage to high frequency 25 kHz (25,000 cylces per second) electrical energy. This electrical energy is transmitted to the transducer within the handpiece, where it is changed to mechanical vibrations. The vibrations from the transducer are intensified by the probe (horn), creating pressure waves in the liquid. This action forms millions of microscopic bubbles (cavities) which expand during the negative pressure excursion, and implode violently during the positive excursion. It is this phenomenon, referred to as cavitation, which produces the powerful shearing action at the probe tip, and causes the molecules in the liquid to become intensely agitated. Energy in water has been increased by physically slamming water molecule together shearing outer covalent electrons off water molecule increasing the energy potential of water because moving the electrons out of orbit via particle oscillation or particle impact.
« Last Edit: March 15, 2010, 07:26:36 am by fastimports3 »
Flame VS Cold Fog Transducer NICE!!!!!!!
Hi Fastimport,
Good tests!
The idea of using fog is a good one, but you still need some hydrogen as catalist to see some chainreaction, in my opinion.
So, not only a flame, but first you need to mix the fog with some hho or H before you ignite it....
UV-C Lighting In chamber to increase energy of water by adding O3 in2 Fog Gen...
Here are some pics...
Nice , very nice, FI!
I have seen those lights  in my petstore. Special lights of cleaning water.
Did you notice any changes?
No on vehicle test run yet... Just got tranny rebuilt for van so I'll be headed back to it soon.... I'll keep ya posted when I get it on the dyno.
