Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 124038 times)
0 Members and 358 Guests are viewing this topic.
Series Style WFC from SS cups powered by Ultrasonic Generator
feature=share&list=UUVJTn7nK_cxU3Shh2o0DExA
« Last Edit: June 20, 2013, 21:18:43 pm by fastimports3 »
Thank you for the zirconia links... just got in.. 14hr days of drilling rock is tiresum :) the last time I searched about zirconia was a thawt of using a sleave of it to depolarize a tube in my old GEET generator so im sure i'll like reading those links :)
Do you remember the circular coil apparartus electrolyzer patent and the old thread at oupower.com about non electrolysis hydrogen generation?
No I was unaware of this post. I'm going to go looking for it now. If you have a link it would be great if you can post it here. I don't believe the process I'm looking to achieve will need electrolyte either. But until I can get it tuned correctly electrolytes of various types are fun to add in very tiny amounts. The reactions are always interesting to observe from combustion to the heating of the fluids involved. I'm curerently back using citric acid again because it hindered the RF heating of power supply and reduced overall temps in cell to 110F max. The ultrasonic HF generator does give your cells strange characteristics across the board. I'm not sure if I showed it in any of the other vids posted but the voltage across the cells when having only one is alot less then when applying lets say 50 cells in series. Will make a vid to show this asap.
do you use salt?
do you use salt?
No, I don't use salt. I use citric acid at the current time if I use any at all. And I use to use Potassium Bicarbonate.
How about this for a coating guys?
http://www.oxititan.com/
It was suggetest by this site to use titanium oxide. It also acts as a diode.
My personal thought is Meyer's drawings are more of a mechanical drawing then literal.
I think we're going to find a coating that does all of this work in one with the WFC.
http://www.ritalie.com/stainless_steel.htm
This is running really close to resonance check it out.
Lights up light bulb not connected to power like a Tesla coil.
« Last Edit: July 12, 2013, 02:39:19 am by fastimports3 »
