Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 156848 times)
Ok guys here's the info we've been missing and if I could figure out this iPad a little better I have a whole bunch more.  Read under number 9 about resistive coating.
Is this similar as the white calcium layer that Ravi and others created during conditioning of the tubes?
Essentially turning the tubes into electrolytic capacitors.
TS
TS
Is this the stuff they might have been coated with possibly?
http://www.ceram-kote.com/products/index.htm
1.0 Scope This is the general specification covering materials and procedures for the thin-film, CeRam-Kote® Ceramic Epoxy coatings. More detailed, job-specific specifications may be obtained from CeRam-Kote, Inc.
3.1 Steel, Stainless Steel, Titanium, Aluminum Grit blast, with sand, steel, garnet, plastic or other media, etc., all metal material ideally to a NACE-1 (SSPC-SP5, Swedish-Sa 3) White Metal but no less than NACE-2 (SSPC-SP10, Swedish-Sa 2 ½) Near White Metal finish. At all times, an anchor profile should be 2 to 2 ½ mils (50 - 62.5 microns).
Powered by Ultrasonic Generator the cell in this vid will have potassium bicarbonate KHCO3 and iodine I.
http://youtu.be/zqcwweHmOL8
« Last Edit: June 04, 2013, 06:10:20 am by fastimports3 »
what if you form a capacitor using water and a higher constant dielectric at the center for more dense electric field lines and connect this water capacitor to a "cold energy" circuit that means no sparks inside water area instead build a tube with nitrogen gas seperate and connect the capacitor in this circuit with the tube ... I still havent built rectifying diodes for thz radiation but water can absorb energy in the very high frequency..if it can store excess energy coming from spark discharge then you can get this energy out one way or another.
« Last Edit: June 04, 2013, 14:56:26 pm by geon »
PDF below is about ionization of water into it's plasma state Brown's gas.
I'm posting a few pieces that best explain what it's is I'm looking to achieve and why it's going to produce more back out of it.
2.4. Ionization Potentials of Ions
The events described by higher-order ionization potentials are very vigorous, even violent: stripping
IO electrons off an atom all at once. This takes explosions, particle beams, etc. There is a much
gentler way to end up with the same end result: strip the electrons off one at a time. (Or add them one
at a time.) The distinction is usually not made clear, but it is well captured in [2] with the attribution
‘Pauling’ for the ‘all-at-once’ event, and the word ‘spectroscopic’ for the ‘one-at-a-time’ process.
Here is a video showing ionization of the water giving instant thermal release of energy.
http://youtu.be/jjKRgeUX5y4
5. Isomers of Water
If water has anything like a plasma state, the molecule approaching that state is certainly not the
ordinary tetrahedral water molecule. So we need to search out one or more isomers of water.
5.1. A Linear Isomer of Water
A linear isomer of water is thought to be the important constituent of the plasma-like phenomenon
known as ‘Brown’s gas’. See, for example, [3,4]. Brown’s gas is of technological interest because it
can perform welding and other technologically important tasks. One particularly interesting property of
Brown’s gas is that it causes no harm when impinging on human flesh. Evidently, that is because the
human flesh does not have metal content; flesh is essentially water, like the Brown’s gas itself is.
The ionic configuration 2H++ O− − previously displaced by 2H−+ O ++ as the candidate for ordinary
tetrahedral water is actually quite interesting in this new context: it could be the ionic configuration for
the linear isomer of water in Brown’s gas. Because all of the electrons in 2H++ O− − are in the
possession of the Oxygen nucleus, the two naked Hydrogen nuclei can settle along the poles of the
Oxygen system. So unlike the 2H−+ O ++ isomer, the 2H++ O− − isomer is not polarized.
Section 3 determined that the formation of water in the ionic configuration 2H++ O− − takes
14.1369 – 13.2419 = + 0.8950 eV, or equivalently 2 × 14.1369 – 27.3788 = + 0.8950 eV. This is a
slightly positive energy. By contrast, the formation of water in the ionic configuration 2H−+ O ++ takes
2 × (−90.6769) + 17.5613 = −163.7925 eV. This is a very negative energy.
Section 4 posited an association between the energy of ionic configuration and physical state of
matter. Observe that Brown’s gas fits the posited association: under conditions where ordinary
tetrahedral water is liquid, the linear isomer is a gas. Observe too that, in an application like welding,
Brown’s gas can be described as ‘burning’. But it doesn’t burn in the usual sense: by oxidation. It need
not consume any oxygen; it can just revert to its normal water isomer. The release of energy makes a
release of light, and at that moment the Brown’s gas may reasonably be regarded as being in the
plasma state.
« Last Edit: June 19, 2013, 14:54:41 pm by fastimports3 »
what pdf?
Sorry guys the pdf is there now...
Ultrasonic Generator 80Khz power HHO CELL 11watts
There is a very small touch of citric acid in the water. Without it the water is heated faster then my microwave boils water. Strange thing here is it requires a small amount of conductivity so the water molecule doesn't just sit there vibrating causing RF heating to take place.  The temp on cell after hours was I first turn the cell on has not gone over 110F.
