Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 150721 times)
« Reply #104 on: October 03, 2011, 15:57:01 pm »
And this is what I came up with copied stans for the most part I have HV DC to hook up to the inside and I'm going to try a spark gap to ground 1st on the extraction grid. Also I need to pulse leds to be 100% as close as I can build to Stans device.
« Reply #105 on: October 03, 2011, 21:17:22 pm »
Well here is what I came up with bolted in place on the van. Only got to run it for a second with fogger HV DC and lights before I heard something arch then inverter loaded up and blew. Will fix inverter tonight. It's nice outside right now.
« Reply #106 on: October 05, 2011, 06:28:35 am »
Cold Fog is being drawn through a HV DC field and photoelectric energizing device with a screen placed right under the clear section of tubing the light is being emitted from and is connected via LED to a screen the is placed at the intake of the cold fog gen device. You can see LED light at the 3:00 min mark. It is extracting it's energy from a grid above the HV and lighted area.
« Reply #107 on: October 05, 2011, 13:28:36 pm »
Hi FI3,
After looking at the video, i was wondering the following.
Do you run that big engine on petrol and you are adding the fog?
« Reply #108 on: October 05, 2011, 13:54:19 pm »
Hi Steve
  That is correct, gm 305 tbi running on gasoline with the fogger piped into the air filter cover above the TBI unit. Last night was the 1st time I saw any real DC coming from the extraction circuit. Not very much at all really, but it's a start. Hope to repair inverter today and test some on road action.
« Reply #109 on: October 05, 2011, 16:49:52 pm »
News announcements and other topics > NewsULTRASONIC PIEZONUCLEAR REACTIONS<< < (6/7) > >> mscoffman:
 Quote from: sparks on January 01, 2010, 01:43:56 AM>>>>    More bubble fusion.  This is how dumb we are.  We have hydrogen produced by the kiloton everyday and distributed at the northpole.  But we are so selfconsumed with the quest for fusion we produce hydrogen expenditure of energy  then we try to fuse it into helium.  More expenditure of energy.  You cant drink helium.  Why wouldnt you just take the hydrogen you are trying to fuse and have it combine with oxygen in a fuel cell.  Hit some water with infrared it gets less dense.  It rises, overcoming gravity.  Hit is with xrays and gammarays what does it do.  Cant electrons and ionized cores be influenced to be classified in the presence of a magnetic field.
You need to look at the energy balance...You fuse Hydrogen to Helium to get
at the Nuclear Binding energy...not because it's the only thing you can do with it.
The Sun does this quite nicely...so everything is cool. The Sun uses only one
ton per day of hydrogen.
:S:MarkSCoffman sparks:
        I just believe that Earth is a great infrared photon capture field.  Every day water molecules capture untold numbers of infrared waves into its molecular vibrations.  If we can design an infrared wave capture system and feed the system with ocean thermal energy we dont need to mess around with mass to energy conversion.  Simply capture the energy condense it pass it through conduits and release it at a latter time.  How dumb can we be.  There are thousands of endothermic reactions that could take place in  oceansubmerged heat exchangers.  The reactions are totally reversible and become exothermic when and where we want them to be.  The presence of catalyzing agents the trick.
Electricity is a catalyzing agent in the exothermic combination of carbon and oxygen.  Magnesium is a catalyzing agent in the ultraviolet cracking of carbon dioxide an endothermic reaction.  We need to study nature and forget about trying to outwit her.  She has a very good head start on us. tinu:
« Reply #110 on: October 08, 2011, 10:44:32 am »
Hi Steve
It will be a challange to find out if you would get more power out then in....
To be honest, i am not sure if thats the goal....
Ionize steam. Use hv and uv.
Tutanka wrote today that if you add a little bit of hho that you might get a better result....
« Reply #111 on: November 02, 2011, 02:57:12 am »
Have you thought about trying infrared? I think more of the light would be absorbed
