Author Topic: Burn rate adjusting of HHO to the level of petrol  (Read 11442 times)
« on: October 25, 2009, 15:23:30 pm »
Some info on adjusting burnrates.
Re: Burn rate adjusting of HHO to the level of petrol
« Reply #1 on: October 27, 2009, 18:50:20 pm »
Good find Steve
The octane rating of H is around 130.
This means that the chances of it igniting from the heat of compression are MUCH lower than with Gasolene.
Increasing the compression ratio of the engine dramatically, or higher turbo boost, will be possible.
This will improve the efficiency of a hydrogen engine, or partial H engine, a lot!
(Increasing compression will allow the use of less H; something that has not been tried or tested in this type of community)
The energy required to ignite H is dramatically lower than that of gasolene however:
This means that any hot spots that were not issues in a gasolene engine may well become issues in a H (or partial H) engine.
Extra care will be needed to round off any sharp edges in the compustion chamber.
This goes hand in hand with the quench distance described in your document, that keeps metal surfaces from melting.
The quench distance of H is about 40% that of gasolene:  0.5mm as opposed to 1.2mm approximately.
This will increase the chances of hot spots dramatically.
It will also cause more heat to make it into the sleeve and head etc, which means that a bigger radiator might be required.
One also has to consider the extra Oxygen that will be in the cylinder from HHO:
This O will displace air; which is  about 78 % Nitrogen, and 2% other stuff.
So  if you displace 1 litre of air with O2 you will have 800 cc more burnable O2!
Nitrogen combines with air during the combustion stroke in an endothermic reaction. (heat used up)
This robs power from the engine, but also keeps temps within design specs.
The best way to get HHO to act more like air in a std. engine is probably the addition of water mist, as already used in Turbocharged  Gasolene Engines, etc.
« Reply #2 on: October 27, 2009, 19:43:29 pm »
Its a subject that needs more investigation.... ;)
« Reply #3 on: October 30, 2009, 01:53:38 am »
The info on octane rating, ignition energy, quench distance etc, is not sucked out of my thumb Steve.
I will find the info and link it, but not now.
Need to get a car running 1st anyway!  :)
« Reply #4 on: October 30, 2009, 13:50:21 pm »
I have done a test with a bottle of hydrogen and i ran my engine perfectly.
So easy too. That was H2.
The thing with HHO is that it is already in a perfect mix, but it doenst have the perfect volume...
« Reply #5 on: April 07, 2010, 08:16:18 am »
you say "Perfect mix" now it is perfect to make water (assuming no other gases are generated) But is that the best mix for power output???
The injection of water mist is a double edged sword. While it will quench hot spots on entry into the engine if an engine is left unsed oxidisation will happen ( this is reduced by the introduction of petrol and oils, maybe an oil additive sprayed with the water mist maybe more benificial)
« Reply #6 on: April 07, 2010, 08:54:41 am »
As HHO the mix is the most powerfull. As soon as you start to change the amount of oxigen or hydrogen, you will have a less powerfull explosion.
HHO as additive to petrol is a totally different story.
Adding water to petrol engines running on petrol is also a different story.
My info is just based on running an ICE on Hydrogen without petrol.
regards
« Reply #7 on: April 07, 2010, 15:09:05 pm »
In the Stephen Meyer Radio interview he says stan started with running a 12 hp motor, then worked his way up, he says it took him years of trying, to get the ratio right
Are you still using your home-made carburator?
