Author Topic: sebosfato projects  (Read 11748 times)
Re: sebosfato projects
« Reply #24 on: September 06, 2015, 15:20:24 pm »
HEY GUYS
LONG TIME HAS GONE
i´m back to the origins somehow...
what are you understanding today about this schematic i proposed on the first posts of this thread?
(http://www.ionizationx.com/index.php?action=dlattach;topic=1216.0;attach=4930)
« Reply #25 on: September 06, 2015, 15:31:27 pm »
today i would look at the electric fields involved not just current..
« Reply #26 on: September 06, 2015, 15:32:38 pm »
I liked that setup..
I even tried it and it works.
Resonance is real here.
« Reply #27 on: September 06, 2015, 15:42:40 pm »
yes bro that thing kind of had its merit...
i remmeber we chating about it...
i end up in my theory to the begining, and started to investigate if my feeling at the time wasnt right...
actualy i think this setup creates a closed loop for the electric fields at the time and so i start to fell it now the same way.... but i want to oscillate with voltage now
what do you think about?
« Reply #28 on: September 06, 2015, 18:28:52 pm »
You mean with starting at low voltage and a minimum of amps...restricting amps as much as possible?
« Reply #29 on: September 06, 2015, 20:11:21 pm »
in our tests i remember we used current to oscilate  the reaction...
the solution was even saturated... i believe than that we could instead just send the high voltage but restricting the amps.. using an even lower capacitance... the parasitic one...
« Reply #30 on: September 06, 2015, 23:18:58 pm »
Not sure Fabio, if this is the way
 But i am also lacking braincells to point out the right one........
Maybe hunt for ac resonance.....and ac hydrogen production...
