Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 168703 times)
« Reply #64 on: October 11, 2009, 22:05:21 pm »
Yea, hopefully after I build the Rotary VIC i'll run a small engine... the maybe build a bigger cell and run a bigger engine.
before trying to get inverters and drive motors and stuff all mounted on a vehicle I think we should do some hard investigating into the setup stan uses in this video
We know this is a tube cell powered by the rotary vic, right?
« Reply #65 on: October 12, 2009, 01:19:35 am »
why not just use only positive outputs from stator... attach neutral side straight to ground..
the effects that i can see are a 50 percent duty supplied by the alternator.. your only relying on positive uni polar pulses into a bifilar choke..  the choke is wound with two wires of equal length.. meaning the energy transmited to one wire is mutually inducted and will apply a potential to the second wire..
the alternator is a ac generator and being rectified will allow it be dc at a 50 percent duty..  the drawing shows the use of the stator neutral in the resonant cavity.. means your pushing just as many electrons into the cell as you are pulling out of the positive choke..
i think if you allow the earth ground to be the negative choke connection rather then to neutral you will be relying more on the force of vacuum then the force of electron in the resonant cavity can show better results...
 think about this as well
whats happening during the 180 out pulse in the stator winding? electrons are being compressed toward the positive chokes diode  then when the positive pulse comes around it has 0 resistance to ground and will start off as a current but it will run out of electron for current. due to the positive chokes resistance to current.. could this create what stan reffered to as the electron bounce phenomenon in secondaries?
now think of this which sounds more harmfull to dielectric and electronic componets?  the force of electrons into choke wires with the use of emf or the force of vacuum to remove them??
now if you were to only use the vacuum on the choke and no force of electrons from the secondarys emf you are only relying on positive pulses to supply the bifiliar  you are forcing a vacuum state to occur in the positive choke.. since for one it is dc.. means current flows one way.. for 2 the only source for electrons if through the water.. at the same time the only source for electrons are across the cell... what is happening to the negative choke when it is fired on by the secondary?  on the positive pulse it is pulsing both positive and negative choke of time when 180 out you are getting a emf pulling electrons out of the negative choke...that does sound like dc to me since the negative gets the effects of the 180 out pulse..
« Reply #66 on: October 12, 2009, 01:27:28 am »
i think stan was using a old school utilities truck inverter to power his electric motor in this video setup above.. on the passenger side is the inverter looks like a electric motor.. the driver side is a electric motor and a alternator... on the first video of stan running the car by his garage you can notice that there is a alternator on the motor bottom rear driver corner in that relative region..
« Reply #67 on: October 12, 2009, 01:32:52 am »
Stan clearly pointed to the above photo, and stated that it was a Boiler "Plate" configeration.
Now I realize, The patent was all about 3 phase, and I also realized the confusing stuff stan adds in really doesn't amount to anything, It just helps keep your mind elsewhere.
Id say he did a pretty good job Patenting his device. If one wanted to, he/she can patent 3 phase while claiming crazy stuff like voltage performs all work, The actual patent does not have to relate to the actual device 1 bit what so ever, he could have very well stated that the device produces flammable water, Just because its in the patent does not make it so, (Its the Law.)
One may have in the past, patented a Walky talky, and given a schematic for how to make Car tires with blue prints in the  patent, Patents does not describe the device, I could patent a round ball, and make the patent about an Iron Brick if i wanted, There is no law against this, In fact, Our law is for it! I could also preach about my Rubber ball by talking about an iron brick, Which is basicly what stan was doing.
« Reply #68 on: October 12, 2009, 01:39:31 am »
Your right.
http://www.ionizationx.com/index.php/topic,258.0.html
But more like 3 phase 220..
« Reply #69 on: October 12, 2009, 03:05:38 am »
All Stans patents were filed under mode of operability, which means you have to demonstrate them to get the patents, and he says he used the boilerplate configuration to get all his patents, so this is the cell he is talking about in his "preferred embodiment" which is always concentric tubular arrays, as he says they are 3.75x more efficient than plates.
You are only going to cloud your understanding of Stans systems of you don't believe the patents are about what they are about. Dynodon has confirmed on numerous occasions that the things he has seen fit exactly with the documentation we have. Which is fabulous for us, and I am thankful for Dynodons contributions and efforts.
If you don't trust stan, you'll never understand him, and this one of the biggest problems I see others having when trying to figure this stuff out.
You have to look at what Stan did and what he talked about and what he wrote down and think why did he do that? What does this do? Which part does this relate too? and soon enough you'll be piecing things together like I have with this topic! We need more people thinking about this information as clues, and to plug everything together. Everything he says adds up if you count all the pieces properly.
« Reply #70 on: October 12, 2009, 04:25:28 am »
Hrm, I would just like to state, The date i registered at waterfuelcell.org is about a month or 2 after i had started researching stan. I would also like to add, eight, (8) hours a day was nothing, I contributed about 12 hours most days, "Including sundays" and to be honest, I do not remember a day that i didn't research stan. Some days "I didn't even sleep."
The research i did was "More" than an 40 hour week job, "I simply loved what i was doing." And, Dating back i have about 3 years Plus "OverTime" Researching nothing but stan. Again, for 3 years, "I isolated my self from the outside world." Up until a few months back, "I backed off."
By now, I think i have a Pretty good ideal what stan was up to, Not to speak, "I spent all me hard earned dollars" on that man.
If you want to end up where I am at, its going to be a long confusing road, I've been down that road already. I'm just stating to you, in my mind, This appears "Silly," Thats as far is i will go with that. I have given Plausable recomendations of how i think stan was running that beetle, And, best by research it best fits his explainitations.
I do not mind watching you, "Try" to attempt the road i've already been down, Which is why i am stepping to the side.
It was my goal to put here what i could Before i ran out of time, It's now here what i wanted to share. It is here now in one spot not strolled all over hundreds of post. These are my words i wish to leave behind, And the words are good.
I wish you all the best of luck, finding resonance of which stan demonstraights, Good Luck.
« Reply #71 on: October 12, 2009, 06:41:30 am »
such a mystery this Meyer like Keeky and Tesla .
These guys were in communication with being of greater existence , that is the only possible answer .
The Meyers cell , How could it be so special ?
How extensive is the tuning involved ?
What is even happening ? How do we even tickle these parameters ?
In my dreams have visions of superposing graphs ...  But I dont even know what those parameters are ? 8)
