Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 168728 times)
« Reply #464 on: October 01, 2013, 12:01:09 pm »
How many poles on your rotor?
How many slots on your stator?=36
Direction of spin?=left
Removal of regulator circuitry, was this done correct?=it had an external regulator.
Komtek,first of all i know how an alt works and with the stock stator works fine,so no brush problem.Secound its not that simple because of the phases shift between them 120 degree out of phase,winding and placing the coils  on the stator i know and did it 10'ns of times.but the relationship between phases i dont know,that must be done corectly or else it will not work ever.
i post a pic with my stock stator and with the part i dont understand.
« Reply #465 on: October 01, 2013, 21:00:18 pm »
All early posts and pictures of the so-called stan alternator have the leads go in and come out 1 slot apart.
This is what I do on every wind that I have done.
Have never wound like yours, so I do not know what will happen.
You would think it would work.
So if you do not wind the lead wire and coil phase by slot/slot/slot can't tell you of any differences.
Also you have not stated poles on rotor?
I would assume 6 plus 6 minus.
« Reply #466 on: October 01, 2013, 23:00:12 pm »
yes 6+   6-
in that picture its factory wound not by me
« Last Edit: October 02, 2013, 01:29:44 am by adys15 »
« Reply #467 on: October 08, 2013, 14:35:19 pm »
This forum is dead?no one can tell me how the phases are aranged?
Komtek i wanna ask you something.What's hapenens when you put a load on the alt?the rotor draws more amps?
« Reply #469 on: October 08, 2013, 20:23:48 pm »
Put your load on the alternator, then adjust strength of rotor magnetic field.
Attach load.
Its easiest to control rotor with DC 0-12 volt just to get the feel.
Without power to rotor there is no power to load.
Rotor draws more amps to power its magnetic field, as you adjust the voltage to it.
I have written many times how to arrange the phases.
Simple KISS 1 2 3 it works.
« Reply #470 on: October 08, 2013, 21:08:01 pm »
Steve except 1 link i viewed all a cople of weeks ago,no such info about phases arangement,believe me i searched all internet.
komtek you told me allright but is ambigous,its like explaning to a doctor how a gearbox works...you can easyly draw a vertical line in paint on my drawing,1picture=1000words...
« Reply #471 on: October 08, 2013, 23:16:29 pm »
but if you leave the rotor voltage\curent fixed what happens when you put a bigger load?
