Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 151240 times)
« Reply #440 on: September 16, 2013, 00:57:50 am »
I understand,you wind them all in one direction on the pipe and then when you removed the pipe you twisted them to become one clockwise one counterclockwise(like in att).The 2 loop coils you made just for demo no?the real stator was 4-filiar?Thanks very much for photos!
« Reply #441 on: September 16, 2013, 01:03:00 am »
in your pic,the two loop ends overlap?if yes it is overlaping on the stator?or the leads join normaly?
« Reply #442 on: September 16, 2013, 01:08:18 am »
Yes it all goes into the slot and at the end it does overlap.
I made this coil just for you, to help explain as visual as I could.
The stator I made is wound as described, 4 wire, 5 turn per coil, 12 coils per phase.
« Reply #443 on: September 16, 2013, 09:15:42 am »
Thanks,for the demo.Still canot understand why your leads join so far from each other,mine join side by side into one slot ,the start wire,coil join with end coil into one slot.
« Reply #444 on: September 16, 2013, 15:38:27 pm »
This is a replication of what I saw in the pic of the Meyer alternator.
I suppose the leads are spread apart so as to connect to the underlying board inside if used.
Otherwise I like the separation if I route them out the casing.
« Reply #445 on: September 16, 2013, 19:14:40 pm »
Thanks,so the wires stick like that just for ease of conection?Here is how i wound mine,the green phase is not totaly drawn to not overcrowd the drawing,and the last finish loop jumps 2slots not 3 like in the pic,because the slots were unclear and drawn wrong,hope you understand,cheers!
« Reply #446 on: September 17, 2013, 01:53:07 am »
If you look at your drawing the final finish wire goes up 3 slots away and not in the same slot.
« Reply #447 on: September 17, 2013, 20:05:20 pm »
i know it has to jump 2 slots,but i tould you already that the pic was unclear and at the end the last  coils jumped 3 ,but in reality the last coil jumps 2 slots and meet with the first  coils in one slot.Apart from this evrything was ok?if yes my start\finish wires does not look like yours..thanks!
