Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 168702 times)
    • dudleys basement
« Reply #272 on: January 10, 2010, 18:57:33 pm »
bifilar wound wire or any wire that is  wound  closely  creates  what is known as corona  when current is flowing thru  it   corona  is a form of static  it will arc across the top of the wire just like the frankenstien movies
their is special wire coating  for this application to prevent the corona from burning up winding it is used in frequency driven motors
 this is why kevin west burns up so many stators
« Reply #273 on: January 10, 2010, 19:36:07 pm »
Thanks for sharing.  What coating is that?  I've been using teflon coated wire silver coated copper like Bob Boyce recommends.  I use the wire to wrap ferrite toroid coils bifilar.  I do have a curiousity towards electric motors and generators/alternators though.  With pulsing dc pwm the coils get hot but with a 60 hz inverter the coils stay cool.  I would like to explore higher frequencies though.
Regards,
Andy
« Reply #274 on: January 10, 2010, 19:51:51 pm »
As far as I know Kevin has not tried a bifiar wind in his stator.
The coating on my wire should stand for 2000 volts, so hopefully it will work. My diodes are rated for 1200 volts.
Once I test it I am going to get it varnished and baked.
« Reply #275 on: January 10, 2010, 21:33:55 pm »
Yes,
And thats why Tesla made aircoils with a spacing between his turns.
« Reply #276 on: January 12, 2010, 03:18:11 am »
Should have this done in a few hours more work... I'm back at school now, so my time is more limited.
(http://img.photobucket.com/albums/v81/bigbuba/Picture59.png)
(http://img.photobucket.com/albums/v81/bigbuba/Picture60.png)
(http://img.photobucket.com/albums/v81/bigbuba/Picture61.png)
« Reply #277 on: January 12, 2010, 15:27:07 pm »
Well done Donald,
Good luck in your further research.
Regards,
Andy
« Reply #278 on: January 13, 2010, 16:13:26 pm »
Impressive build, Donald!
Thumbs up for you!
« Reply #279 on: January 13, 2010, 17:40:56 pm »
Thanks guys, i'll be working on it more soon, only a few more things to do before it's operational.
