Author Topic: IonizationX reference circuit for waterfuelcells  (Read 7101 times)
Re: IonizationX reference circuit for waterfuelcells
« Reply #8 on: August 30, 2009, 01:15:11 am »
hello Steve
it is been a while i know  :-[
how much improvement did you get on this technique bemf .
Thank you
Najman
« Reply #9 on: August 30, 2009, 11:04:35 am »
hello Steve
Thank you
Najman
That depends on total setup. Its hard to say.
This schematic was given to RAVI by Aussepom and you all know what Ravi is claiming.
If you are gonna build this, then try to use plates in serie. Or 1 circuit per tube.
Its, because of the impedance. When its too low, you will never see nice spikes on yr scope.
More tubes in parallel, are giving less then 1 ohm! NOT good.
I also suggest that you play with the mark/space. 50% is way too less power in the system.
Well, take some parts you already have and use a big core. I use a MOT primairy coil. Other coils are cut off. Bifilar is better, but 2 single coils work as well.
The result is so depening on the water type too.
« Reply #10 on: August 31, 2009, 17:03:17 pm »
the original one
« Reply #11 on: September 01, 2009, 16:35:52 pm »
Ok so after i a lot of consideration (5min ;D ) i took the plunge and made the bifillar coil ,material used:
2 x 100 feet cooper wire 14 awg .
spool dimension  130MM  X 50MM
3M scotch tape
total cost 25$ Canadian .
total turns +- 152 turns
total time  2 hours
tools used both my hands witch this morning i cannot feel them  >:(
now i have to order the diodes to complete and test the BEMF.
Najman
Re: IonizationX reference circuit for waterfuelcells Cramton circuit
« Reply #12 on: January 23, 2011, 07:51:02 am »
(http://www.ionizationx.com/file:///C:/Users/Alen/Desktop/Phase%20lock%20included.png)Ran across a circuit fro(http://www.autismpedia.org/wiki/images/0/03/Cramton_circuit.png)m a fellow named Cramton. I includes the PLL circuit
« Reply #13 on: January 23, 2011, 09:05:15 am »
 8)
looks like a proper pll circuit to me!
Thanks for posting :)
